    LoPy to LoPy: Raw LoRa sf
    loramacraw loraspreading facto
    2 Posts 2 Posters 171 Views 2 Watching
      GMB124
      Hi everyone!
      I'm working with raw LoRa (LoRaMAC) and I use two LoPy-4 board: one transmits whereas the second one receives.
      I've been working using spreading factor (sf) 7, and now I want to test other spreading factor values using the command lora.sf([value]). However, when I change the sf of the transmitted packet, my nanogateway doesn't see the packets anymore.
      Node code:
      import os
      import struct
      from network import LoRa
      # A basic package header, B: 1 byte for the deviceId, B: 1 byte for the pkg size
      _LORA_PKG_FORMAT = "BB%ds"
      _LORA_PKG_ACK_FORMAT = "BBB"
      DEVICE_ID = 0x01
      # Open a Lora Socket, use tx_iq to avoid listening to our own messages
      # Asia = LoRa.AS923
      # Australia = LoRa.AU915
      # Europe = LoRa.EU868
      # United States = LoRa.US915
      lora = LoRa(mode=LoRa.LORA, tx_iq=True, region=LoRa.EU868)
      lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
      lora_sock.setblocking(False)
      lora.sf(8)
      while(True):
          # Package send containing a simple string
          msg = "Device 1 Here"
          pkg = struct.pack(_LORA_PKG_FORMAT % len(msg), DEVICE_ID, len(msg), msg)
          lora_sock.send(pkg)
          # Wait for the response from the gateway. NOTE: For this demo the device does an infinite loop for while waiting the response. Introduce a max_time_waiting for you application
          waiting_ack = True
          while(waiting_ack):
              recv_ack = lora_sock.recv(256)
              if (len(recv_ack) > 0):
                  device_id, pkg_len, ack = struct.unpack(_LORA_PKG_ACK_FORMAT, recv_ack)
                  if (device_id == DEVICE_ID):
                      if (ack == 200):
                          waiting_ack = False
                          # If the uart = machine.UART(0, 115200) and os.dupterm(uart) are set in the boot.py this print should appear in the serial port
                          print("ACK")
                          waiting_ack = False
                          print("Message Failed")
          time.sleep(5)
      Receiver code:
      import struct
      # A basic package header, B: 1 byte for the deviceId, B: 1 byte for the pkg size, %ds: Formatted string for string
      _LORA_PKG_FORMAT = "!BB%ds"
      # A basic ack package, B: 1 byte for the deviceId, B: 1 byte for the pkg size, B: 1 byte for the Ok (200) or error messages
      # Open a LoRa Socket, use rx_iq to avoid listening to our own messages
      # Asia = LoRa.AS923
      lora = LoRa(mode=LoRa.LORA, rx_iq=True, region=LoRa.EU868)
      while (True):
          recv_pkg = lora_sock.recv(512)
          if (len(recv_pkg) > 2):
              recv_pkg_len = recv_pkg[1]
              device_id, pkg_len, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
              print('Device: %d - Pkg:  %s' % (device_id, msg))
              print(lora.stats)
              ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, 1, 200)
              lora_sock.send(ack_pkg)
      I think I have to change some receiver settings, but I don't know how.
      Thank you for your help!
        lmo
        Just guessing, but you should probably set the same spreading factor on the receiver also?
