Parameter substitution in webhook integration URL
 I need to substitute a device name into the web hook URL where it says DEVICE_NAME below - is this possible? https://webhook.site/b2b7af39-b94f-4677-9542-d8dd549476a2/api/v1/DEVICE_NAME/telemetry
 @johand Yes it is on pybytes - sorry for confusion - I am trying to move from particle.io platform and gain similar functionality. I will keep looking around for a solution
 @ShanevanJ Is this Pybytes webhook? I thought it was something you were doing on the device... Maybe you can post to your own service and there convert to a request with the device name in the url. I looks like there will be some kind of device id in the request body.
 @johand - Ah I was too quick here ... The integration page shows the new url as this Endpoint Address
 https://webhook.site/b2b7af39-b94f-4677-9542-d8dd549476a2/apiv1/{}/telemetry.format(MyDevice)- No "{}"
 and it won't accept with leading " marks either
 @johand Thank you - I am a python noob so I should have guessed the solution would be pythonic ! (how do we add this to the documentation for the web hooks - would save a lot of time!)
 @ShanevanJ said in Parameter substitution in webhook integration URL: https://webhook.site/b2b7af39-b94f-4677-9542-d8dd549476a2/api/v1/DEVICE_NAME/telemetry "https://webhook.site/b2b7af39-b94f-4677-9542-d8dd549476a2/api/v1/{}/telemetry".format("MyDevice")Johan
