crcmod
Does somebody know if there is an implementation of crcmod available for mircopython?
I need to calculate crc for 16bits values.
I have a DALLAS 1Wire implementation.
I'm sure you can find look up values to change it to the CRC8 you require.
def crc8Nib (data):
CRC8_TABLE_SML1 = bytes([0x00, 0x5e, 0xbc, 0xe2, 0x61, 0x3f, 0xdd, 0x83, 0xc2, 0x9c, 0x7e, 0x20, 0xa3, 0xfd, 0x1f, 0x41])
CRC8_TABLE_SML2 = bytes([0x00, 0x9d, 0x23, 0xbe, 0x46, 0xdb, 0x65, 0xf8, 0x8c, 0x11, 0xaf, 0x32, 0xca, 0x57, 0xe9, 0x74])
try:
crc = 0xFF # 0xFF seeded
for x in data:
t = (x ^ crc) & 0xFF
crc = CRC8_TABLE_SML1[t & 0x0f] ^ CRC8_TABLE_SML2[t >> 4]
return crc;
except ValueError:
pass
Thxs for you answer.
Do you also hava a CRC8 function which is able to do the following?
Width: 8 bit
Polynomial 0x31 (x8 + x5 + x4 + 1)
Initialization 0xFF
Final XOR: 0x00
Examples: CRC (0xBEEF) = 0x92
@gertjanvanhethof
This is my CRC16 function based on a very common CRC16 method.
Perhaps it will help you.
You may need to change the seed value to 0x0000, depending on what CRC16 you are hoping to implementdef crc16Nib (data):
CRC16_TBL_SML = ([0x0000, 0xCC01, 0xD801, 0x1400, 0xF001, 0x3C00, 0x2800, 0xE401, 0xA001, 0x6C00, 0x7800, 0xB401, 0x5000, 0x9C01, 0x8801, 0x4400,])
crc = 0xFFFF # 0xFFFF seeded
for x in data:
crc = CRC16_TBL_SML[(x ^ crc) & 0x0F] ^ (crc >> 4) # because using the reflected algorithm, the low nibble is processed first
crc = CRC16_TBL_SML[((x >> 4) ^ crc) & 0x0F] ^ (crc >> 4)
return crc;
