    What needs to be done to support 6lowpan via slip via uart ?
    Scheduled Pinned Locked Moved Enhancements
    1 Posts 1 Posters 110 Views 1 Watching
    • M Offline
      mexx4711
      Hi Devs,
      excellent work you have done so far - congratulations !
      i got my nb-iot sim card from magenta today, ten minutes after fw upgrade i was able to send out my first udp packets ! - GREAT !
      as i am also experimenting with 6lowpan (contiki os), i want to connect them to my FiPy in order to query the 6lowpan nodes via CoAP and send the responses to my server via NB-IoT.
      therefore the question is what needs to be done in order to add this functionality to micropython ?
      on the linux side this is done with a tool called tunslip6 which bridges the 6lowpan via slip to a tun device on the pc.
      i checked out pycom-micropython-sigfox from github and to my surprise i found 6lowpan and slip code in lib/lwip/src/netif.
      so how can this be integrated in a custom build ?
      how does the socket code know how to interface with the network devices ?
      what about the AbstractNIC stuff that is documented in docs/library/network.rst ?
      and how would i set this up under micropython ?
      i am experienced python and embedded programmer (ported pymite a couple years ago), so no problem to get my hands dirty with this !
      i think i haven't found the correct documentation, or "big picture" on how the things are connected - also not on the micropython page ... :(
      so please, point me in the right direction or give me some hints so that i can bring this to life ;)
      regards,
      mexx.
