When is the TX_PACKET_EVENT interrupt triggered?
  • Hi,
    I am using LORA RAW communication based on a socket: socket.socket(socket.AF_LORA, socket.SOCK_RAW), with an interrupt handler for both TX_PACKET_EVENT and RX_PACKET_EVENT.
    I would like to know when is the TX_PACKET_EVENT being triggered?
    Is it once the message is transmitted or once it is inside the socket's buffer?
    • Afaik, the socket has some sort of buffer (fifo?) which stores messages when I call socket.send(msg), and LoRa messages are being transmitted from this buffer.
    Another question is, can this buffer be emptied in case I only want the last message to be sent and not in order?
    I hope I'm not missing anything with the behaviour I just described.
    Regards,
    Eran
  • @jcaron thanks! That is clearly a good way of doing that. How come I didn't think of it sooner? :)
    Here is what I sent:
    24 byte payload (on top of headers, CRC, etc.)
    SF12
    US915
    BW500
    The time between when I sent it to when I got the interrupt triggered is: ~460 mili seconds
    The expected time between when I sent it to when I got the interrupt triggered should be: ~450 mili seconds
    So that means that the interrupt is triggered after the entire message has been sent.
    Hopes that helps anyone.
    Regards,
    Eran
  • @eranroll It should be easy to find out by yourself: send a few 50-byte packets at the slowest possible data rate (SF12 in the EU region for instance). Such packets will take over 1 second to send, so logging the events with timestamps should give you a pretty clear answer.
    Don't forget to report back your findings.
