    Setting bluetooth characteristic in new firmware
    7 Posts 5 Posters 237 Views 5 Watching
      lmo
      Hello!
      I'm trying to use Wipy as a BLE sensor. The following code is working on firmware 1.18.2.r7. I'm using the nRF Connect and with notifications enabled, characteristic changes are updated.
      But with newer firmware it crashes on chr1.value(i) with "OSError: Erorr while sending BLE indication/notification".
      from network import Bluetooth
      bt = Bluetooth()
      bt.set_advertisement(name='test-sensor', service_uuid=b'1234567890123456')
      bt.advertise(True)
      srv1 = bt.service(uuid=0x3000, isprimary=True, nbr_chars=1)
      chr1 = srv1.characteristic(uuid=0x3001, properties=Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value=0)
      i = 1
      while i < 10:
          chr1.value(i)
          print('characteristic value = '+str(i))
          time.sleep(5)
          i+=1
      J A 2 Replies Last reply Reply Quote 0
        jcaron @lmo
        @lmo not sure I ever played with the BLE stuff on the Pycom modules, but shouldn’t you need to wait for a connection before sending updates? Though it would seem legitimate for it to just cache the value and don’t send anything if there’s no connection.
        Does it throw on the first call, or after a few updates?
          lmo
          Thanks @jcaron, that was it. It would be nice if the characteristic could be set even if no client is connected, but I can probably work around that.
            Ajneal @lmo
            @lmo
            I have the same issue.
            Anyone have a fix for this problem?
            • N Offline
              nowakowski912 Banned
              • W Offline
                wituwitu
                I also have this problem... I tried with another similar code, but the same error "OSError: Erorr while sending BLE indication/notification" is displayed on chr1.value(val).
                Anyone got a fix?
                  jcaron @wituwitu
                  @wituwitu According to the answer from @lmo, you can only set the characteristic once you actually have a client connected. You'll get an error if you try to set it when there's no client.
