Q: preferred / suggested way to do full (including filesystem) WiPy / xxPy erase ?
Whereas it is rather helpful that the scripts / filesystem survive a firmware update/upgrade - is there a preferred/suggested way to (e.g. using esptool.py with what command line?) fully erase all the data on a WipY / xxPy and really "start from zero" with programming firmware?
best regards
Ralf
@ubiq_01, you can connect to your device and perform:
import os os.mkfs('/flash')
That will format the internal storage to it's factory state. Hope it helps ;)
1 out of 2
