    understanding accelerometer wake example
    accelerometer
    11 Posts 3 Posters 264 Views 3 Watching
    • N Offline
      NicolaC
      Hi to everyone,
      I have one Lopy4 and one pytrack ex. board (version 1.1)
      I'm trying to run the example of the site:
      https://docs.pycom.io/pytrackpysense/apireference/sleep/
      but I really dont understand how it works.
      My purpose is to get the type of the interrupt (time or accelerometer) and to send some data via LoraWan.
      For now I just want to test this example (No Lorawan).
      I'm using visual studio code IDE and the operation I do is simply :
      1. click "upload" button
      2. click the "run" button
      The problem is : what should I expect from this script in the terminal you see attached?Accelerometer.png
      It seems the code is running ! am right?
      but if I shake the board nothing happens.
      Please advice on what I'm doing wrong!
      Nico
        jcaron @NicolaC
        @NicolaC One problem with that code is that when it goes to sleep it will disconnect USB, and when it wakes up it takes a little while for USB to come back up, but it will go back to sleep before it's up.
        You should probably change the LED color on boot, based on the wake reason, if you want to see what happens.
          andreas
          Dear Nicola,
          the code you are showing is probably not even starting. Please try to rename your file from Main.py to main.py and try again.
          With kind regards,
          Andreas.
          N 1 Reply Last reply Reply Quote 1
          • N Offline
            NicolaC
            @jcaron said in understanding accelerometer wake example:
            Hi jcaron,
            thanks for reply,
            I have put a comment to the print statements at the begining and I have put the following code:
            #print("Wakeup reason: " + str(py.get_wake_reason()))
            #print("Approximate sleep remaining: " + str(py.get_sleep_remaining()) + " sec")
            if (str(py.get_wake_reason())==1):
                time.sleep(2)
                pycom.rgbled(0x7f7f00) # yellow
                time.sleep(2)
            but it doesnt seem to work .
            Do I have to close the IDE ?
            Do I have to power from external power supply?
            I really dont understand the flow of the code.
            Please help
            • N Offline
              NicolaC @andreas
              @andreas thanks,
              I have the file to "main.py" and it seems to work but:
              • at the boot when no accelermoter event occurs it gives me the yellow led (its right)
              • then when I shake it , it seems to give me the green led but it doesnt take 2 sec. as designed in the code and it soon
                switches to the yellow again .
                Do you know why?
              • N Offline
                NicolaC @jcaron
                Hi @jcaron,
                I have make steps forward in order to send LoraWan packet on GPS event but I cant discriminate the accelerometer wake event from boot one. this is what i did:
                1)configured one Fipy as nanogateway (properly connected to TTN)
                2)flashed the following fw on the end device :
                the if (str(py.get_wake_reason())==1)
                doesnt seem to work since the led is always yellow.
                Any Ideas?
                These is my code:
                import math
                import network
                import os
                import utime
                import gc
                from machine import RTC
                from machine import SD
                from L76GNSS import L76GNSS
                from pytrack import Pytrack
                from LIS2HH12 import LIS2HH12
                from network import LoRa
                import ubinascii
                import binascii
                import struct
                time.sleep(2)
                gc.enable()
                py = Pytrack()
                l76 = L76GNSS(py, timeout=30)
                #lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868,device_class=LoRa.CLASS_A)
                #lora.nvram_restore()
                def loraSend (msg):
                    # Initialize LoRa in LORAWAN mode.
                    # Asia = LoRa.AS923
                    # Australia = LoRa.AU915
                    # Europe = LoRa.EU868
                    # United States = LoRa.US915
                    print("dentro:sto mandando....."+msg)
                    lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
                    dev_addr = struct.unpack(">l", binascii.unhexlify('xxxxxxx'))[0]
                    nwk_swkey = binascii.unhexlify('xxxxxxxxxxxxxx')
                    app_swkey = binascii.unhexlify('xxxxxxxxxxxxxxxxxxxxxx')
                    # join a network using ABP (Activation By Personalization)
                    print("join finito")
                    # create a LoRa socket
                    # set the LoRaWAN data rate
                    # make the socket blocking
                    # (waits for the data to be sent and for the 2 receive windows to expire)
                    s.setblocking(True)
                    # send some data
                    print("scoppio?")
                    #s.send(bytes(msg))
                    s.send(msg.encode('utf-8'))
                    print("non scoppio")
                    # (because if there's no data received it will block forever...)
                    s.setblocking(False)
                    print("fine")
                def returnGps ():
                    lat=None
                    lng=None
                    gpsResult=None
                    timer=30
                    while(timer!=0 and ((lat==None)or(lng==None))):
                        print("getting coordinate")
                        time.sleep(0.9)
                        timer=timer-1
                        gpsResult = l76.coordinates()
                        lat=gpsResult[0]
                        lng=gpsResult[1]
                        print ("LAT is: "+str(lat)+"\r\n")
                        print ("LONG is: "+str(lng)+"\r\n")
                        if (lat!=None and lng!=None):
                            print ("found coordinate")
                            break
                    return gpsResult
                    pycom.rgbled(0xFF0000) # red
                    time.sleep(5)
                    c=returnGps()
                    print ("prparing data")
                    strToSend="shake\LAT:"+str(c[0])+"\LONG:"+str(c[1])
                    loraSend(strToSend)
                    print("sending lora data")
                    print ("LAT is: "+str(c[0])+"\r\n")
                    time.sleep(5)
                    c=returnGps()
                    strToSend="Alive\LAT:"+str(c[0])+"\LONG:"+str(c[1])
                    loraSend(strToSend)
                # enable wakeup source from INT pin
                py.setup_int_pin_wake_up(False)
                acc = LIS2HH12()
                # enable activity and also inactivity interrupts, using the default callback handler
                py.setup_int_wake_up(True, True)
                # set the acceleration threshold to 2000mG (2G) and the min duration to 200ms
                acc.enable_activity_interrupt(2000, 200)
                # go to sleep for 5 minutes maximum if no accelerometer interrupt happens
                py.setup_sleep(60)
                py.go_to_sleep()
                # while True:
                #     time.sleep_ms(300)
                #     print("xxxxxxxxxxxxxxxxxxxxxrikkion")
                # c=returnGps()
                # print ("LAT is: "+str(c[0])+"\r\n")
                Any suggestion non what I 'm doing wrong?
                Nicola
                  andreas @NicolaC
                  Dear @NicolaC,
                  str(number) == 1
                  will always yield False as any string will never equal a number. You should probably omit the conversion to String by str().
                  With kind regards,
                  Andreas.
                  • N Offline
                    NicolaC @andreas
                    Hi @andreas
                    thanks ,
                    now it seems to work.
                    I will test and let you know.
                    • N Offline
                      NicolaC @NicolaC
                      Hi Andreas,
                      I'm doing some test to understand if it works but I would like to shutdown GPS before going to sleep and turn on it when it wakes up.
                      I'm using :
                      py.set_bits_in_memory(PORTC_ADDR, 1 << 7)
                      to shut down and
                      for turning on. But how can I define PORTC_ADDR?
                      I have an error because its not defined
                      Could you help me ?
                      Nicola
                      • N Offline
                        NicolaC @NicolaC
                        Hi guys,
                        I have modified the code by defining a new method in the pycropoc.py file:
                        def gps_state(self, gps=True):
                             # enable or disable back-up power to the GPS receiver
                             if gps:
                                 self.set_bits_in_memory(PORTC_ADDR, 1 << 7)
                                 self.mask_bits_in_memory(PORTC_ADDR, ~(1 << 7)
                        and I shutdown the GPS before to go into sleep while I switch on it when i wake up.
                        At the moment I have these issues:
                        • even with this new function the power consumption does not change
                        • When I wake up from cyclic sleep the LED is RED ("shock" event ) and not yellow (only sometimes is yellow) as I expected. However The shock waking event seems to work (always red as expected)
                        Could you please advice on what I'm doing worng for both issues ?
                        Awaitng your reply
                        Nicola
                          jcaron @NicolaC
                          @NicolaC The PORTC configuration will be changed during the go_to_sleep call. You should just add an argument false to that call to disable the GPS (the argument is optional and defaults to true).
