    Fipy, Creating a new file on SD card, but it is protected (no access)!
    6 Posts 2 Posters 259 Views 2 Watching
    • R Offline
      railmonitor
      Hello everyone.
      I am having some trouble with Micropython, probably it's just me who is doing something wrong. What i want, is to be able to dynamically create a new .txt file on my SD card for the FiPy, and then append data to that file. I am able to create new files without any problems, but when i want to write to them, i get the following error:
      File "main.py", line 51, in <module>
      File "main.py", line 38, in save_record
      OSError: [Errno 13] EACCES
      I have been using the examples shown here:
      https://docs.pycom.io/firmwareapi/pycom/machine/sd/#app
      https://docs.pycom.io/firmwareapi/micropython/uos/
      I am trying to structure my code as a class, here is what i have so far:
      class DB():
          record_taken = None
          pending_data = False
          data_ready = False
      #Constructor initiates SD card object and mounts the card
          def __init__(self):
              sd = machine.SD()
              os.mount(sd, '/sd')
      #Method which creates a new record, name is based on the time argument
          def new_record(self, time):
              self.time = time
              uos.mkdir('/sd/'+'record_'+str(time))
      #Method to append data to a record, record is again based on time argument
          def save_record(self, data, time):
              f = open('/sd/'+'record_'+str(time), 'a')
              f.write(data)
              f.close()
      #Method to save a records data in variable, to be used for publishing etc.
          def get_record(self, time):
              self.record_taken = open('/sd/'+'record_'+str(time), 'r')
      #Method to delete a record, again with the name being decided by the time argument
          def delete_record(self, time):
              self.uos.remove('/sd/'+'record_'+str(time))
      dibs = DB()
      dibs.new_record(22)
      dibs.save_record("testdata", 22)
      line 51 is the dibs.save_record(xxx)
      line 38 is f = open('/sd/'+'record_'+str(time), 'a')
      So it would seem that the new file i am creating has somekind of protection on it, that prevents me from opening it. What am i missing?
      robert-hhR R 2 Replies Last reply Reply Quote 0
        robert-hh @railmonitor
        @railmonitor You try to write to a directory, which you created with mkdir. If you want to a file with that name, the mkdir (or call to new_record) is not required. The call to open() with the 'a' mode will create the files if it does not exist yet.
        • R Offline
          railmonitor @railmonitor
          @railmonitor said in Fipy, Creating a new file on SD card, but it is protected (no access)!:
          Okay - i think i found the error myself just now - the uos.mkdir() method is for creating new directory, not a file, and ofc i cannot write directly in a directory.
          This naturally gives rise to another question: How do i create new files on my SD card, without manually mounting the SD card on my PC and creating the file that way?
            @railmonitor The call to open() with the 'a' mode will create the file if it does not exist yet.
            • R Offline
              railmonitor
              @robert-hh Thanks alot, i was beginning to figure it out myself. A related question is how to delete a file, can it be done without a call to uos.remove()?
              Is there something along the lines of this that will work (i tried a delete / remove but these are not known attributes)?:
              f = open('/sd/record_1.txt')
              f.delete()
                @railmonitor yes. uos.remove() is the method for deleting files.
