    Timer.Alarm nested in another Timer.Alarm possible?
    3 Posts 3 Posters 126 Views 3 Watching
    • R Offline
      railmonitor
      Hi.
      I am able to use the Timer.Alarm() without any problems normally.
      But i run into problems when i have a Timer.Alarm() nested inside of a method that is called by another Timer.Alarm().
      I am creating a program, which is supposed to use lightsleep mode until a wakeup from the accelerometer.
      The program has two Timer.Alarms running in main() which starts when it wakes up. One of these runs a method which initiates yet another alarm to take measurements from the accelerometer. But it seems this alarm is never activated. So is this sort of "nesting" of Timer.Alarms not possible / bad practice, and what is the alternatives?
      I am posting a example here, i hope it is understandable without you needing the whole of my main().
      #Initial Alarm
      activity_alarm = Timer.Alarm(lambda y: timer_sampler(), s = 1, periodic = True)
      #The method that the activity_alarm uses, which starts yet another alarm (ignore the prints for debugging)
      def timer_sampler():
          print("Entering timer_sampler() method!")
          global is_active
          acc.set_odr(6)
          acc.set_full_scale(3)
          acc.enable_activity_interrupt(126, 10)
          if acc.activity():
              print("There is activity in timer_sampler() method!")
              if is_active == False:
                  is_active = True
                  print("Starting ALARM!!")
                  alarm = Timer.Alarm(lambda x: sample(), ms = 10, periodic = True)
          #elif not acc.activity():
          print("There is now NO activity in timer_sampler() method!")
          if is_active == True:
              is_active = False
              alarm.cancel()
      • R Offline
        roy Taylor
        did you get it to work .
        My timer only works once then stops , Even if the periodic = true
          robert-hh @railmonitor
          @railmonitor You do not need the lamda function for setting the callback. Simply giving the name of the callback function is sufficient.
          Timer.Alarm(timer_sampler, s = 1, periodic = True)
          Obviously, the function timer_sampler has to be placed in your script before using if for the alarm callback notification, and the callback has to have a single argument, the alarm object.
