GPY LTE modem connection first attemp
Hi I am using GPY 1.0 and through pycom software update 1.16.2 it was upgraded to 1.20.0.rc13
I am trying to use LTE feature , first I run the command : sqnsupgrade.info () and this is the result :
My first question is why it appears UEUnknown , and if I should upgrade the modem firmware.
I am using a SIM card from local company in Argentina whose apn is datos.personal.com , should I define this before running the command ?
I work in this cellular company so I can get info of other parameter if necessary
@kjm updated the modem
I will try , if any doubt I will post here.
Thanks !
33080 is old firmware but still usable, 41065 was the latest last time I looked. Ignore the UEUnknown.
Before attempting attachment you need to give the modem your Telco's details. Probably something like lte.send_at_cmd('AT+CGDCONT=1,"IP","datos.personal.com"')
