    GPY continuously rebooting rst:0x7 (TG0WDT_SYS_RESET)...
    3 Posts 2 Posters 209 Views 2 Watching
      Tiit
      The GPY module was used with user program. Then I needed to use it for another purpose, I reinstalled FW (tried multiple versions from 1.20.rc4 to most new one, all in legal or pybytes settings); flash was deleted/formatted along with fw installation and also afterwards in ATom REPL to get a clean module. (Using Exp board v. 3.1)
      The GPY keeps restarting with:
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:2156
      ho 0 tail 12 room 4
      load:0x4009fa00,len:19208
      entry 0x400a05f4
      Initializing filesystem as FatFS!
      I found similar issue in ESP32 forum: https://github.com/espressif/esp-idf/issues/7
      Pls help - how to get rid of this using pycom REPL? (I'm not experienced hacker in ESP kernel...). The same module does not give also WIFI access point when powered up.
      • K Offline
        kjm
        1. Not all flash erasures are created equal, the one that definitely does a full flash erase runs not from Atom but the windows cmd line with Atom closed down. My notes on same herewith:
          Full flash erase using pycom-fwtool-cli (P2 to gnd, press reset button on dev2.0 board)
          cd \Program Files (x86)\Pycom\Pycom Firmware Update
          pycom-fwtool-cli list to get com port eg COM3
          pycom-fwtool-cli.exe -p COM3 erase_all (gives ‘access denied’ if Atom using the port)
        2. Maybe try reflashing with littleFS option in lieu of FatFS?
          Tiit
          It really worked! Thank you so much, KJM!
          What I did:
          Connected P2 to GND, pressed reset on Exp Board v3.1. The connection P2 to ground was left on for all the deleting process time.
          Then I did as instructed and result is clean module; reflashed fw as usual with FAT and everything worked and I was able to update NB modem. Also, the previously disappeared wifi at power up was back.
          The problem is associated probably with using adhoc wifi and filezila before I tried to clean the module for another application.
          C:>cd Program Files (x86)
          C:\Program Files (x86)>cd Pycom
          C:\Program Files (x86)\Pycom>cd Pycom Firmware Update
          C:\Program Files (x86)\Pycom\Pycom Firmware Update>
          C:\Program Files (x86)\Pycom\Pycom Firmware Update>pycom-fwtool-cli list
          COM6 [USB Serial Device (COM6)] [USB VID:PID=04D8:EF98 SER=PY7C4EA8 LOCATION=1-1]
          COM3 [Intel(R) Active Management Technology - SOL (COM3)] [PCI\VEN_8086&DEV_A13D&SUBSYS_07D01028&REV_31\3&11583659&0&B3]
          C:\Program Files (x86)\Pycom\Pycom Firmware Update>pycom-fwtool-cli.exe -p COM6 erase_all
          Running in PIC mode
          Erasing the board can take up to 40 seconds.
          Board erased successfully in 11.61 seconds
