    Pytest integration
    4 Posts 2 Posters 80 Views 4 Watching
      Summer
      any way to get pytest for micropython?
      https://docs.pytest.org/en/latest/
        andreas
        Dear @Summer,
        pytest itself will probably never work on MicroPython. You might also want to follow the discussion at [1].
        However, we have been working on building a test harness for our Terkin Datalogger based on pytest just a few days ago, see [2]. The main job was to apply appropriate mocking to the MicroPython ESP32 HALs and to make different modules from the MicroPython standard library compatible with CPython.
        So, the test harness will not run on the device itself, but within a regular CPython. Let me know what you are aiming at and if I can support you in any way. In fact, I was planning to put all generic parts into a different package so it can be reused by others.
        With kind regards,
        Andreas.
        [1] https://github.com/pfalcon/pycopy-lib/issues/49#issuecomment-603875987
        [2] https://github.com/hiveeyes/terkin-datalogger/tree/master/test
          Summer
            Summer
            Thank you for the interesting informations, I want exaclty to be able to develop without having to load the software on the boards to test it.
            I'll look at your implementation, thank you for sharing!
            Best regards
