LTE NB-IoT won't connect to T-Mobile NL
  • Hello,
    My GPy won't attach to the t-mobile nb-iot network anymore.
    I'm running to following code:
    lte.attach(band=8, apn="cdp.iot.t-mobile.nl")
    Then I wait for lte.isattached() becomes True, but it doesn't.
    When I'm sending 'AT+SQNMONI=9', I'll get:
    '\r\n+SQNMONI: vodafone NL Cc:204 Nc:04 RSRP:-74.60 CINR:0.00 RSRQ:-11.10 TAC:12407 Id:36 EARFCN:6254 PWR:-55.72 PAGING:256\r\n\r\nOK\r\n'
    I'm expecting T-Mobile NL or "LMN ID: 20416 (20416 is T-Mobile NL - MCC - MNC)"
    Yesterday my project was working fine and sending battery status.
    Does someone has an solution for me?
  • @rfinkers We had a similar problem last week with an sma to ipx adapter cable. Inspection with a magnifying glass showed one of the bifurcated connectors in the ipx plug that mates with the centre pin of the gpy lte antenna socket was missing leading to intermittent lte reliability. Those miniature RF connectors are not well suited to the repeated plug/unplug cycles typical of development work.
  • Okay, my problem is fixed.
    I flashed the sequans modem again and I tested my code again. But it was still not working.
    I wiggled the cable of the antenna a bit and it connected to the network!
    I think the antenna of my gpy wasn't connected properly or the antenna cable is broken or something.
  • @kjm Thnx for your support.
    The sim was working properly, but I start to doubt it.
    I get the following response:
    simreg = 0 service = 0
    I'll also contact T-mobile if they know a solution.
  • @rfinkers Unreal!
    1. Are you sure the sim is current?
    2. What does it say for sim=lte.send_at_cmd('at+creg?').split(',')[1][:1]; ser=lte.send_at_cmd('AT+cind?').split(': ')[1][2]; print('simreg =', sim, 'service =', ser)
  • The following code will give this output.
    import os
    from network import LTE
    import usocket
    def send_at_cmd_pretty(cmd):
        response = lte.send_at_cmd(cmd).split('\r\n')
        print('Sent to modem: \'{}\''.format(cmd))
        for line in response:
            if line.strip() != '':
                print(line)
    # Print module details
    un = os.uname()
    print('Sysname:', un.sysname)
    print('Release:', un.release)
    print('Version:', un.version)
    print('Machine:', un.machine)
    # Initialize LTE object
    lte = LTE()
    time.sleep(5)
    # Pre attaching debugging
    print('Query LTE modem imei...', lte.imei()[:5] + '*' * 10)
    print('Query SIM iccid...', lte.iccid()[:5] + '*' * 15)
    send_at_cmd_pretty('ATI1')
    send_at_cmd_pretty('AT!="showver"')
    send_at_cmd_pretty('AT!="RRC:setDbgPerm full"')
    send_at_cmd_pretty('AT!="RRC:showcaps"')
    time.sleep(5)
    send_at_cmd_pretty('AT+SQNCTM?')
    # Attach LTE
    print('LTE attaching...')
    attempts = 0
    while not lte.isattached():
        time.sleep(5)
        attempts = attempts + 1
        print('Attaching...', attempts)
        if attempts % 15 == 0:
            send_at_cmd_pretty('AT+SQNMONI=9')
            send_at_cmd_pretty('AT+CEREG?')
            send_at_cmd_pretty('AT+CFUN?')
            send_at_cmd_pretty('AT+CSQ')
            send_at_cmd_pretty('AT!="showphy"')
            send_at_cmd_pretty('AT!="fsm"')
    print('LTE attach succeeded!')
    # Debug attached state
    send_at_cmd_pretty('AT+CGPADDR')
    send_at_cmd_pretty('AT+PING="172.27.131.100"', delay=5000)
    # Connect LTE
    lte.connect()
    attempts = 0
    while not lte.isconnected():
        time.sleep(5)
        print('Connecting...', attempts)
    print('LTE connection succeeded!')
    # Test DNS
    try:
        usocket.dnsserver(0, '8.8.8.8')
        usocket.dnsserver(1, '1.1.1.1')
        usocket.dnsserver()
        print(usocket.getaddrinfo('www.google.com', 80)[0][-1])
    except Exception:
        print('DNS over NB-IoT failed...')
    # Send message to dashboard
    s = usocket.socket(usocket.AF_INET, usocket.SOCK_DGRAM)
    s.setsockopt(usocket.SOL_SOCKET, usocket.SO_REUSEADDR, 1)
    # s.settimeout(5)
    # s.setblocking(False)
    s.sendto(bytearray('Hello World!'), ('172.27.131.100', 15683))
    s.close()
    # Shutdown LTE
    print("Disonnecting LTE ... ")
    lte.disconnect()
    print("Detaching LTE ... ")
    lte.dettach()
    print("Shuttting down LTE...")
    lte.deinit()
    Output:
    Sysname: GPy
    Release: 1.20.2.rc6
    Version: v1.11-01f49f7 on 2020-02-28
    Machine: GPy with ESP32
    Query LTE modem imei... 35434**********
    Query SIM iccid... 89882***************
    Sent to modem: 'ATI1'
    UE6.0.0.0
    LR6.0.0.0-41019
    OK
    Sent to modem: 'AT!="showver"'
    SYSTEM VERSION
      FIRMWARE VERSION
        Bootloader0  : 5.1.1.0 [39529]
        Bootloader1* : 6.0.0.0 [41019]
        Bootloader2  : NA
        NV Info      : 1.1,0,0
        Software     : 6.0.0.0 [41019] by robot-soft at 2018-12-13 21:41:15
        UE           : 6.0.0.0
      COMPONENTS
        ZSP0         : 1.0.99-3171
        ZSP1         : 1.0.98-3170
    OK
    Sent to modem: 'AT!="RRC:setDbgPerm full"'
    OK
    Sent to modem: 'AT!="RRC:showcaps"'
    == CAPS config =============================
      .Lock UE on SRV band    : false
      .MFBI support           : true
      .TM8 TDD support        : false
    == CAPS ====================================
      . access stratum: R13
      . catM          : 1
      . nb-IoT        : 1
    -- EUTRA bands --
      . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
      . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
      . admin         :
      . pending admin :
    -- EUTRA carriers --
      . admin         :
      . pending admin :
    OK
    Sent to modem: 'AT+SQNCTM?'
    +SQNCTM: standard
    OK
    LTE attaching...
    Attaching... 1
    Attaching... 2
    Attaching... 3
    Attaching... 4
    Attaching... 5
    Attaching... 6
    Attaching... 7
    Attaching... 8
    Attaching... 9
    Attaching... 10
    Attaching... 11
    Attaching... 12
    Attaching... 13
    Attaching... 14
    Attaching... 15
    Sent to modem: 'AT+SQNMONI=9'
    +SQNMONI: 20416 Cc:204 Nc:16 RSRP:-84.80 CINR:0.00 RSRQ:-11.70 TAC:1552 Id:97 EARFCN:3747 PWR:-65.32 PAGING:1024
    OK
    Sent to modem: 'AT+CEREG?'
    +CEREG: 2,0
    OK
    Sent to modem: 'AT+CFUN?'
    +CFUN: 1
    OK
    Sent to modem: 'AT+CSQ'
    +CSQ: 23,99
    OK
    Sent to modem: 'AT!="showphy"'
    DL SYNCHRO STATISTICS
        Synchro state                         : CELL_ACQUIRED
        PPU SIB1 ACQ watchdog                 : 0
        Frequency Hypothesis RF  (Hz)         : 0
        RSRP (dBm)                            : -84.63
        RSRQ  (dB)                            : -11.64
        Channel estimation state (Cell-spec.) : HIGH CINR
        Channel estimation state (UE-spec.)   : LOW CINR
        Channel estimation state (MBSFN)      : LOW CINR
        Channel estimation CINR               : 8.65
        Channel length                        : SHORT
      AGC
        AGC RX gain (dB)                      : 46.39
        RX PSD BO (dBFs)                      : -20.92
        RX PSD (dBm)                          : -87.20
        Noise level RS (dBm)                  : -92.59
        Digital gain (dB)                     : 4.30
        CINR RS (dB)                          : 7.96
      NARROWBANDS
        Last DL NB                            : Central
        Last UL NB                            : 0
      AFC
        Frequency offset RF  (Hz)             : -1286
        Frequency offset BB  (Hz)             : 0
      PBCH
        MIB received quantity                 : 0
        MIB timeout quantity                  : 0
    OK
    Sent to modem: 'AT!="fsm"'
    SYSTEM FSM
        |            FSM           |        STATE       |
        | RRC TOP FSM              |CAMPED              |
        | RRC SEARCH FSM           |CAMPED_ANY          |
        | RRC ACTIVE FSM           |IDLE                |
        | PMM PLMN FSM             |ANY_CAMPED          |
        | EMM MAIN FSM             |NULL                |
        | EMM AUTH FSM             |NULL                |
        | EMM CONN FSM             |NULL                |
        | EMM TAU FSM              |NULL                |
        | EMM TEST FSM             |NULL                |
        | ESM BEARER FSM           |BEARER_NULL         |
        | SMS MT FSM               |IDLE                |
        | SMS MO FSM               |IDLE                |
        | LPP FSM                  |IDLE                |
        | HP MAIN FSM              |IDLE                |
        | HP USIM FSM              |READY               |
        | HP SMS MO FSM            |IDLE                |
        | HP SMS MT FSM            |IDLE                |
        | HP CAT FSM               |IDLE                |
    OK
    Attaching... 16
    etc
  • The response is:
    ['', '+CPIN: READY', '', 'OK', '']
    It still won't attach...
  • You can check your modem with m=lte.send_at_cmd('at+cpin?'); m=m.split('\r\n'); print(m), it should attach if m has READY or SYSSTART in it
