not receiving BLE notifications on pycom fipy
I am trying to receive bluetooth NOTIFY messages using the FiPy.
The script I am running is as follows:
from network import Bluetooth def mycb(chr): print("Callback succesful!") bt = Bluetooth() if not bt.isscanning(): #scan for devices bt.start_scan(-1) while True: adv = bt.get_adv() if adv and adv.mac == b"my_dev_mac": try: conn = bt.connect(adv.mac) services = conn.services() for service in services: if service.uuid() == b'my_serv_uuid': chars = service.characteristics() for char in chars: if char.uuid() == b'my_char_uuid': char.callback(trigger = Bluetooth.CHAR_NOTIFY_EVENT, handler=mycb)
Using a different app (nRF on android) I can see the NOTIFYs being transmitted, so it's certain they are being transmitted. Reading and writing values also works fine, however the callback does not seem to work.
What am I missing?
Sincerely,
Robert
@jcaron I am sure that the callback works, I have gotten into the callback when using the nRF connect app as a server and sending notifications with that server. However after further tracing, it seems that I cannot properly subscribe to the NOTIFY characteristic. To subscribe for notifications it seems that you have to send a value to the descriptor, not the characteristic as I have been trying. The same problem got mentioned here: https://github.com/pycom/pycom-micropython-sigfox/issues/37, although it is still not clear how to write to the descriptor. Is there any way to write to the descriptor?
@Robert-N I mean, are you sure ˋchar.callback` is actually called? Add a trace there to make sure that happens. Just to make sure it’s not some stupid typo or something that prevents it from being executed.
@jcaron I am certain the services and characteristics are being transmitted, as I can read them. I am not quite sure what you mean by "callback being correctly installed", do I need to install the callback seperately? Is this not something that works out of the box?
@Robert-N have you checked that you actually get the service and characteristic and that the callback is correctly installed?
