UART parity always None?
Hi guys, I'm currently trying to get the uart of my Wipy 2.0 working, but I can't change the parity of the UART object. I tried setting the parity in the constructor and also with init method. Neither UART.ODD nor UART.EVEN worked, I always ended up with parity=None when printing the uart object to the console. My firmware version is 1.5.0.b2
Can anybody help? -
Just for fun, did you try changing bits number also ?
Yes I tried different combination with data, parity and stop bits, but no effect. Even with UART(0, parity=UART.ODD) I get parity=None returned.
Yes, there is a small bug on esp32/mods/machuart.c
// parity uint32_t parity; if (args[2].u_obj == mp_const_none) { parity = UART_PARITY_DISABLE; } else { uint parity = mp_obj_get_int(args[2].u_obj);Last line (350) should not have the
uintas that is shadowing the intented parity variable defined above. -
Many thanks! So I will wait for the next update..
