    VS code + Pymakr unable to connect to the LoPy4
    2 Posts 1 Posters 75 Views 1 Watching
      jpmjpmjpm
      I am trying to program a LoPy4 + Expansion Board v3.1. VS + Pymakr is not able to connect to the LoPy4.
      My setup is the following one:
      • OS: Ubuntu 18.04.
      • Virtual Studio Code 1.43.2
      • Pymakr 1.1.6
      I successfully upgraded the Expansion Board v3.1 with expansion31_0.0.11.dfu firmware.
      I successfully upgraded Lopy4 firmware at 1.20.2.rc6 firmware level.
      lsusb recognizes the device:
      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 008: ID 06cb:00bd Synaptics, Inc.
      Bus 001 Device 005: ID 5986:114e Acer, Inc
      Bus 001 Device 007: ID 1d5c:7102
      Bus 001 Device 003: ID 14cd:8601 Super Top
      Bus 001 Device 031: ID 046d:082d Logitech, Inc. HD Pro Webcam C920
      Bus 001 Device 030: ID 046a:0023 Cherry GmbH CyMotion Master Linux Keyboard G230
      Bus 001 Device 029: ID 413c:a503 Dell Computer Corp.
      Bus 001 Device 028: ID 046d:c063 Logitech, Inc. DELL Laser Mouse
      Bus 001 Device 027: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
      Bus 001 Device 032: ID 04d8:ef98 Microchip Technology, Inc.
      Bus 001 Device 010: ID 8087:0aaa Intel Corp.
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      The command screen /dev/ttyACM0 115200 hangs.
      When I use Pymakr > Extra > List Serial Ports, /dev/ttyACM0 (Pycom) (copied to clipboard) is detected.
      However, I'm unable to connect to the device using Pymakr > Connect. The connection is hanging.
      Additional remarks:
      • I get the same behavior with another LoPY4 device.
      • I get the same behavior when I connect the LoPY4 devices to PySense devices.
      • My LoPy4 devices are connected to a LoRa antenna.
      • I tried on another computer... with same results.
      • I tried with another USB cable... same results again.
      Any clue of what can be wrong?
        jpmjpmjpm
        Thanks to Pycom support, the issue was solved by a format of the whole Flash Memory using pycom-fwtool-cli -p <port> erase_all command and flashing again the firmware.
