    Pymakr doesn't find any serialports
    5 Posts 3 Posters 120 Views 3 Watching
    • M Offline
      MadMe86
      Hello!
      i just looked for a IDE to get in Touch with my ESP32-Cam, so i found VSC and Pymakr.
      Now i encountered a problem. Pymakr wont find any Serial Devices. :-/
      Tested on Ubuntu (i think 18.04) and Arch Linux.
      When i trigger "List serial ports"
      Found 0 serialport (nothing else)
      My shell:
      MadMe86@MyPC ~ % ls -la /dev/ttyU*
      crw-rw---- 1 root uucp 188, 0 13. Apr 18:55 /dev/ttyUSB0
      and i am in the uucp group(Thats the Arch dialout group). Thonny is connecting just fine.
      My Device is an ESP32-Cam. (Should be compatible with Pymakr, right?)
      I tried VSC and Atom(on Arch) but both don't show any serial devices. On the Ubuntu machine i tested the app with VSC as snap package and as native installed app.
      Am i missing something?
      Thanks in Advance!
      MadMe86
        cdjambov
        @MadMe86 said in Pymakr doesn't find any serialports:
        Try adding pymakr.conf into the project folder and fill it with something like this.
        "address": "/dev/ttyUSB0",
        "username": "micro",
        "password": "python",
        "sync_folder": "",
        "open_on_start": true,
        "safe_boot_on_upload": false,
        "py_ignore": [],
        "fast_upload": false
        • M Offline
          MadMe86
          • M Offline
            MadMe86 @cdjambov
            @cdjambov
            Thanks for your reply!
            but that did not do the trick... still the same...
            Are there any log files which i could check? or a verbose mode to activate?
            • V Offline
              vicvaquero
              @MadMe86 maybe its a permission problem. I had a similar issue and this solved it for me.
              sudo chmod 666 /dev/ttyUSB0
              let me know if this solved your problem or how did you fixed it.
              Cheers
