    LoPy4 boot.py Wifi
    6 Posts 2 Posters 99 Views 2 Watching
    • N Offline
      nemke.petrovic
      Hi all
      I am new
      I like to have script in boot.py in Lopy4 for Wifi. So I have connection all time with devices. No mater waht happed to main.py code to have access to change it.
      Also I need to use external Antenna for wifi (alredy connected), so in script I like to specific antenna=WLAN.EXT_ANT and mode to be STE
      My wifi Network is secure auth=WPA2, and I like dhcp to assigne IP to LoPY4 (I configure MAC IP reservation on router, so same IP is given to module)
      Help. I need example of this script ?
        robert-hh @nemke.petrovic
        @nemke-petrovic you can put any code into boot.py. Did you have a look at the examples in the documentation? E.g. https://docs.pycom.io/tutorials/all/wlan/
        • N Offline
          nemke.petrovic
          Yes, of course. But didn't manage to work.
          So, i write here maybe someone have working script
            @nemke-petrovic You could try that one, which is except for the antenna switch the one I am using:
            def do_connect():
                import network
                wlan = network.WLAN(mode=network.WLAN.STA) # create station interface
                wlan.antenna(WLAN.EXT_ANT)
                if not wlan.isconnected():      # check if the station is connected to an AP
                    wlan.connect(ssid=WIFI_SSID, auth=(network.WLAN.WPA2, WIFI_PASSWD))
                    for _ in range(100):
                        if wlan.isconnected():      # check if the station is connected to an AP
                            break
                        print('.', end='')
                        time.sleep_ms(200)
                        print("Connect attempt timed out\n")
                        return
                print('\nnetwork config:', wlan.ifconfig())
            do_connect()
            WIFI_SSID and WIFI_PASSWD have to be set accordingly.
            • N Offline
              nemke.petrovic @robert-hh
              from network import WLAN
              wlan = WLAN() # get current object, without changing the mode
              if machine.reset_cause() != machine.SOFT_RESET:
                  wlan.init(mode=WLAN.STA)
                  # configuration below MUST match your home router settings!!
                  # change the line below to match your network ssid, security and password
                  wlan.connect('IoT Network', auth=(WLAN.WPA2, '19Akacki_Ryu86'), timeout=5000)
                  while not wlan.isconnected():
                      break
              Interesting, it doesn't work. I write new using examples from pycom documenty, end this is work.
              LoPy4 ver 1.20.2.rc6
              Many thanks for reply
                @nemke-petrovic The break statement in the last line is wrong. That way, the code will not wait for a connection. And also, the antenna is internal.
