    SiPy Firmware Update
    11 Posts 2 Posters 155 Views 2 Watching
      Gus79
      Hi!
      I'm trying to update Sipy to get ID/PAC Sigfox.
      The board works fine so I can read values from bme280,
      The problem is when try to update. I get this:
      Any suggestion, please?
        robert-hh @Gus79
        @Gus79 How do you connect your SiPy to your PC? Maybe you could try a lower baud rate using the --speed 460800 option for 460800 baud.
          Gus79 @robert-hh
          @robert-hh I tried with 460800 as you suggest and also with 115200. Same result.
            robert-hh @Gus79
            @Gus79 How do you connect your PC to the SiPy?
              Gus79 @robert-hh
              @robert-hh UART
                robert-hh @Gus79
                @Gus79 UART means: a generic USB/UART bridge? Did you pull P2 low and push reset before starting the upload?
                  Gus79 @robert-hh
                  @robert-hh yes, i did. I've been searching in the forum but... nothing for me
                    robert-hh @Gus79
                    @Gus79 It still looks like a communications problem. Did you use that method before or it is your first attempt?
                      robert-hh @Gus79
                      @Gus79 Another question: where did you get the firmware tarball from?
                        Gus79 @robert-hh
                        @robert-hh It's the first time. I downloaded tarball from pycom github.
                          robert-hh @Gus79
