    Error instantiating the SD module.
    3 Posts 2 Posters 65 Views 2 Watching
    • V Offline
      VST Admin
      This morning I started up a sample program I was attempting to write to log serial data to an SD Card, connected to an expansion board 3. I didn't get very far before this:
      # main.py -- put your code here!
      from machine import UART
      from machine import SD
      import os
      sd = SD()
      Gives me the error:
      Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms
      WiFi connection established
      Pybytes connected successfully (using the built-in pybytes library)
        File "main.py", line 10, in <module>
      OSError: the requested operation failed
      Pycom MicroPython 1.20.2.rc6 [v1.11-01f49f7] on 2020-02-28; GPy with ESP32
      A version of this code was at least running without error yesterday, (even though it was not writing any data to the SD Card. This morning, I start the same code I was running and I get the above error message. That makes no sense to me.
      • R Offline
        railmonitor
        Could there be something happening in your boot.py file that impacts the code in your main? Maybe doing the same operation?
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          VST Admin @railmonitor
          @railmonitor Nothing changed though in my boot.py (which is empty) from one day to the next. However, I believe the internal machinations of the UART and the SD card modules are somehow stepping on each other's proverbial toes.
          I have sense gotten my experiment to work again, but I have no idea why it is working now and why it gave me those messages the other day.
