Pymakr on VSCode under WSL
  • Hi,
    Has anyone tried to run Pymakr extension on VSCode under WSL (Windows Subsystem for Linux) by any chance?
    I can run pymakr on vscode under pure windows 10 without any problems. But when I install pymakr extension on WSL VSCode the pymakr command palette doesn't work. Dev Tools Console throws a couple of errors:
    • "Error while loading serialport library"
    • "Error: Could not locate the bindings file."
    Please, if some of you successfully run pymakr on VSCode under WSL, could you share your installation hints and the way you solved these issues.
    Thanks!
