this code is breaking my sipy
  • this code is breaking my sipy
    from machine import UART
    uart=UART(1, baudrate=9600)
    uart.init(9600, bits=8, parity=None, stop=1)
    while(1):
    print(uart.readall())
  • gps...
    i kind of found part of the problem...
    the on the boot.py i had
    import os
    uart = UART(0, 115200)
    os.dupterm(uart)
    and on my main.py
    uart=UART(1, pins=("G2", "G1") )
    pycom.rgbled(0x000000)
    while(1):
    maybe having uart on the boot and main.py files is conflicting... gonna change them
  • @iotmaker
    just curious
    what you have connected on uart1? GPS, phone...?
  • @livius said in this code is breaking my sipy:
    @iotmaker
    ok - then this must be something in pymakr
    but did you tried wifi AP+STA?
    you then can connect to router and in the same time connect to Wipy/LoPy
    thanks livius... yes thats the weird thing. it works with wifi, i can connect my laptop to the sipy wify and connect the pymakr without problem..
    i will see what else i can do..
  • @iotmaker
    @iotmaker
    i still do not understand you
    please back to previous post and look at my sample
    do you have it in boot.py?
    import os
    os.dupterm(uart)
    above duplicate rerminal on uart0 have you it in boot.py or not?
    without duplicate terminal you can not work on COM throught Pymakr
    Yes i have that code on the boot.py
  • @iotmaker
    import os
    os.dupterm(uart)
  • i just want to download and connect to the sipy via Serial or COM. but when i switch on the interface menu to use my COM port it cant connect. i dont like to connect to the sipy wifi everytime to download code.
  • @iotmaker said in this code is breaking my sipy:
    but i think you cannot use the COM port to download programs if you are using a program that uses the comport to print to the screen
    I do not understand your answer
    But first, what are you trying to do? for what is your modification about uart1? You have some device on UART1? And UART/USB converter on UART0? Or what?
    Secondly you can use AP+STA mode of wifi.
    @iotmaker
    what if you change it to
    while(1):
        machine.idle()
    I am not at home to try.
    i dont want to be switching my wifi connection every time i want to download something.
  • @iotmaker
    while(1):
        machine.idle()
    @iotmaker
    What do you mean it work on putty? To work with pymakr you need duplicate terminal.
    What is your boot.py is it standard as:
    import os
    os.dupterm(uart)
    If answer is yes, then your code only print all data from UART1 as output on UART0
    yes thats what my code is doing. on the pymakr console i cannot see my prints. only on putty. ( i have putty closed when trying pymakr of course cant use the com port on two programs).
    after the program is running i cant connnect to the sipy and download programs via serial port. Is that normal?
    do i need to turn on the wireless everytime i want to download a program?.. .thanks
  • @iotmaker
    import os
    os.dupterm(uart)
  • the code is worky using putty and it does not work on the pymakr console...
    so are we supposed to download programs vi the wifi and then run the serial port on putty or what?
  • now i can only connect via wifi
