    Mac - VS Code - PyMakr
    3 Posts 2 Posters 69 Views 2 Watching
    • K Offline
      kkerem
      VS Code pymakr console goes into infinite loop with following error message:
      The terminal process terminated with exit code: 1
      execvp(3) failed.: No such file or directory
      Can someone explain how to fix it or is there some workaround.
      My SW versions are the following:
      VS Code version: 1.45.1
      Node.js: 12.8.1
      OS: Darwin x64 19.4.0
      Pymakr: 1.1.6
      P 1 Reply Last reply Reply Quote 1
        pyfun @kkerem
        @kkerem i gave up trying to fix and instead moved over to using Atom, which works well.
        I think the issue could be to do with pymakr being unable to find node due to some path issue, but never managed to find a working solution.
        • K Offline
          kkerem @pyfun
          @pyfun thanks, figured it as well, would prefer VS code still
