GPy Modem (NB1) Firmware Update
Hi everyone,
I am following tutorial:
https://docs.pycom.io/tutorials/lte/firmware/I have used this FAT file system on SD:
Format your SD card as with the FAT file system and then copy the files onto the card using your computer
>>> from machine import SD >>> sd = SD() >>> os.mount(sd, '/sd') >>> os.listdir('/sd') ['n\x03', '\x12\x13\x02"P#\x04@."'] >>> import sqnsupgrade >>> sqnsupgrade.run('/sd/NB1-41019.dup', '/sd/updater.elf') <<< Welcome to the SQN3330 firmware updater [1.2.6] >>> >>> GPy with firmware version 1.20.2.r3 Exception when checking file /sd/updater.elf... wrong file name? [Errno 2] ENOENT False
It seems files can not be read from sd.
>>> import sys >>> sys.version '3.4.0' >>> sys.platform 'GPy'
Thank you in advance for your assistance.
Regards, Vojtech
@nadvorvo Good that it worked. The SD card support of these littel boards is a little bit picky. If you have a SD card that works well, keep it for that purpose. I personally have good experience with Sandisk cards.
I do not believe the the fail on the first attempt was related to the SD card. The error message originates from the modem firmware.
@robert-hh @kjm Thanks a lot for writing back.
The problem was really in SD, I have taken another one (16GB Kingstone) and file listing is fine.>>> from machine import SD >>> sd = SD() >>> fs = os.mkfat(sd) >>> os.mount(sd, '/sd') >>> os.listdir('/sd') ['System Volume Information', 'updater.elf', 'NB1-41019.dup']
Upgrade procedure started, but there is another problem (Code download failed[1], aborting!)
>>> import sqnsupgrade >>> sqnsupgrade.run('/sd/NB1-41019.dup', '/sd/updater.elf') <<< Welcome to the SQN3330 firmware updater [1.2.6] >>> >>> GPy with firmware version 1.20.2.r3 /sd/updater.elf is not required. Resumining normal upgrade. Firmware file is too big to load via FFF method. Using ON_THE_FLY Attempting AT wakeup... Session opened: version 1, max transfer 8192 bytes Sending 5835531 bytes: [ ] 1%Wrong SRSP signature: 0x0D0A4552 SRSP header too small: 9 Code download failed[1], aborting! True >>>
I am trying another SD (32GB Scandisk Extreme) ... succeeded
>>> sqnsupgrade.run('/sd/NB1-41019.dup', '/sd/updater.elf') <<< Welcome to the SQN3330 firmware updater [1.2.6] >>> >>> GPy with firmware version 1.20.2.r3 Attempting AT auto-negotiation... Session opened: version 1, max transfer 2048 bytes Sending 371307 bytes: [########################################] 100% Waiting for updater to load... Attempting AT wakeup... Session opened: version 1, max transfer 8192 bytes Sending 5835531 bytes: [########################################] 100% Waiting for modem to finish the update... <<<=== DO NOT DISCONNECT POWER ===>>> Resetting.................................... Your modem has been successfully updated. Here is the current firmware version: UE6.0.0.0 LR6.0.0.0-41019 IMEI: 354347095120116 True
@nadvorvo If you have the option, try a different SD card of moderate size, like 8 or 16 BGByte. Remove all partitions using a partition manager and create a new one.
RE: pins used to drive the sd card .... I am using expansion board V3.1 (no other devices connected, only GPy and ExpansionBoard)
RE: I don't see the fs=os.mkfat(sd) cmd ... I made a new test. Still not working.
>>> from machine import SD >>> sd = SD() >>> fs = os.mkfat(sd) >>> os.mount(sd, '/sd') >>> os.listdir('/sd') ['n\x03', '\x12\x13\x02"P#\x04@."']
RE: SD card must have single FAT partition
I have single FAT partition
@nadvorvo The SD card must have single FAT partition. New SD cards sometimes have a different partition structure. If you cannot see the files with uos.listdir(), then the firmware update will not work.
Have you checked the 3 pins used to drive the sd card (P8:DAT0, P23:SCLK and P4:CMD) are otherwise unused on your board? Also I don't see the fs=os.mkfat(sd) cmd anywhere?
