    Connected via AT&T iot sim stopped working
    2 Posts 1 Posters 46 Views 1 Watching
    • I Offline
      irfan5911
      Using Gpy with expansion board 3. I was able to setup and connect using AT&T iot sim using:
      # While the configuration of the CGDCONT register survives resets,
      # the other configurations don't. So just set them all up every time.
      print("Configuring LTE ", end='')
      lte.send_at_cmd('AT+CGDCONT=1,"IP","m2m.com.attz"')
      print(".", end='')
      lte.send_at_cmd('AT!="RRC::addscanfreq band=17 dl-earfcn=5780"')
      print(".", end='')
      lte.send_at_cmd('AT+CFUN=1')
      print(" OK")
      Then registered the device through pybytes and did an integration azure.
      Now the device does not connect. re installed firmware for modem and gpy.
      Any suggestions?
      • I Offline
        irfan5911 @irfan5911
        @irfan5911 figured it out. correct band and earfcn are crucial.
