    board goes to sleep befote it sends out data to pybytes
    1 Posts 1 Posters 21 Views 1 Watching
      j_mor
      Hi all,
      I've run into an issue using pybytes on my LoPy4 with Pysense shield.
      I would like to get data from sensors, send them to Pybytes and go to deepsleep.
      I do have sepadate funcions to get the data from sensors and to send the data.
      Simplified code without any definitions and library imports:
      sensorData = getSensorData()
      sendData(sensorData)
      py.setup_sleep(sleepTime)
      py.go_to_sleep()
      The getSensorData() returns JSON dictionary with all the sensor data.
      The sendData() looks like this:
      def sendData(data):
          pybytes.send_signal(1, data['batt'])
          pybytes.send_signal(2, data['temp1'])
          pybytes.send_signal(3, data['press'])
      (two dots represent more lines in the function, 9 values are being sent, wanted to save some space :) )
      The problem is that calling sendData() jumps out immediately and the actual data sending process takes on later. From what I understand pybytes.send_signal() sets up a new thread with given arguments and is done.
      So when I run the code, LoPy goes to deepsleep before it actually sends out any data to Pybytes.
      Is there any flag or variable I could check to see if my Lopy board is still sending out the data and in that case wait before going to deepsleep??
      Something like:
      while(True):
          if not "pybytes_still_sending_data":
              py.go_to_sleep()
      Possible workaround may be to put time.sleep() for like 20 sec before the deepsleep, but I would like to avoid this "solution".
      Thank you,
      j_mor
