    Pytrack gps None,None
    6 Posts 3 Posters 214 Views 5 Watching
    • R Offline
      rholas
      I try to start my pytrack board with Lopy4 but gps get only None,None.
      I went out into the garden for 20 mins but still not lock gps, program wait for gps signal.
      import ubinascii
      import network
      from network import LoRa
      from L76GNSS import L76GNSS
      from pytrack import Pytrack
      from LIS2HH12 import LIS2HH12
      from machine import ADC
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
      # create an OTAA authentication parameters
      dev_eui = ubinascii.unhexlify('7XXXXXXX')
      app_eui = ubinascii.unhexlify('A7415FCXXXXXX')
      app_key = ubinascii.unhexlify('6A42ED2XXXXXXXXXXXXXX')
      lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=4)
      pycom.rgbled(0x7f0000)
      while not lora.has_joined():
          time.sleep(5)
      pycom.rgbled(0x00007f)
      s.setblocking(True)
      py = Pytrack()
      l76 = L76GNSS(py, timeout=60)
      acc = LIS2HH12(py)
      s.setblocking(False)
      gpsResult = l76.coordinates()
      print(gpsResult[0])
      while gpsResult[0] != "None":
              time.sleep(5)
      pycom.rgbled(0x007f00)
          coord = l76.coordinates()
          accel = acc.acceleration()
          battery = py.read_battery_voltage()
          s.send(str(coord)+":"+str(accel)+":"+str(battery))
          time.sleep(60)
      • R Offline
        rholas
        • R Offline
          rholas
          • R Offline
            rholas
            Modify code to work with L76GNSV4.py
            import ubinascii
            import network
            from L76GNSV4 import L76GNSS
            dev_eui = ubinascii.unhexlify('70B3DXXXX')
            app_eui = ubinascii.unhexlify('A74XXXXX')
            app_key = ubinascii.unhexlify('6A42ED2AXXXXX')
            # join a network using OTAA (Over the Air Activation)
            # wait until the module has joined the network
                time.sleep(5)
            # create a LoRa socket
            # set the LoRaWAN data rate
            # make the socket blocking
            # (waits for the data to be sent and for the 2 receive windows to expire)
            s.setblocking(True)
            # send some data
            #s.send(bytes([0x01, 0x02, 0x03]))
            py = Pytrack()
            L76 = L76GNSS(pytrack=py)
            L76.setAlwaysOn()
            acc = LIS2HH12(py)
            # (because if there's no data received it will block forever...)
            ##s.setblocking(False)
            L76.get_fix(debug=False)
            if L76.fixed():
                pycom.rgbled(0x000f00)
                coord = L76.coordinates(debug=False)
                ido = L76.getUTCDateTime(debug=False)
                s.send(str(coord)+":"+str(accel)+":"+str(battery)+":"+str(ido))
                time.sleep(60)
            Get data from my car over Lora:
            {'latitude': 47.XX636, 'longitude': 16.XX56, 'ttf': 1}:(-0.5155029, -0.3260498, 0.8127441):3.84871:2020-06-17T09:35:44+00:00
              Jean-Guillaume LALANNE @rholas
              Hello @rholas
              I have seen your post on this forum thread.
              I have the same problem.
              (None, None) - (1970, 1, 1, 0, 0, 7, 439353, None) - 2544192
              (None, None) - (1970, 1, 1, 0, 0, 9, 436383, None) - 2544384
              (None, None) - (1970, 1, 1, 0, 0, 11, 433600, None) - 2544384
              (None, None) - (1970, 1, 1, 0, 0, 13, 431573, None) - 2544384
              (None, None) - (1970, 1, 1, 0, 0, 15, 428571, None) - 2544384
              I have tried to use the L76GNSV4 file as you mentioned and I found it here
              But I don't get anything. It seems blocked.
              What should I do ? I use the reference code from the pytrack 2 documentation and I get None for the coordinates and when i use L76GNSV4, nothing happen.
              thanks in advance for your help
              Best regards
                As mentioned before, GPS reception inside is generally very poor, so the result is as expected when using it inside.
                Next, if you are using the external antenna on the pytrack2, make sure the jumper labelled AON is also present.
                Let me know
