    UART
    5 Posts 2 Posters 112 Views 2 Watching
      loics
      I have trouble understanding UART communication on the FiPy.
      I use a FiPy 1.0, and Pysense but only for Vin, GND, TX0 and RX0 (simpler for me), the rest is done on a breadboard.
      Using ATOM text editor, and the following test code :
      uart = UART(1)
      uart.init(9600, bits=8, parity=None, stop=1, pins=('P3','P4'))
      compteur = 0
          pycom.rgbled(0x001000)
          uart.write("\x30\x31\x32\x33")
          time.sleep_ms(100)
          input = uart.read()
          if input is not None:
              compteur += 1
              print("INPUT : " + str(compteur))
              print(input)
          pycom.rgbled(0x000000)
          time.sleep_ms(1000)
      If I connect P3 and P4 with a jumper, I get :
      INPUT : 1
      b'0123'
      INPUT : 2
      b'0123'
      INPUT : 3
      b'0123'
      in the ATOM editor log (as expected).
      However, when I try to read the output with a USB->RS232 converter, my COM debuging software (Docklight) receives (in hex)
      D6 B6 96 06
      And the FiPy reads a giant byte string composed of hundreds (600-700) of '\x00', even though nothing is sent.
      If I switch RX/TX then nothing happends, so that is not the issue. The FiPy is up to date.
      Do you have any ideas or recommandations for further testing ?
      PS : I can use this USB->RS232 converter and Docklight to succesfully chat with other devices such as industrial tiltmeters.
        crumble
        You are naming it wrong.
        Have a look on the syntax highlighting of input. It is marked red, because input() is an internal function. Rename your variable to something safe like my_input and try it again.
          loics
          Thanks for noticing that, ATOM does not highlight "input" as a keyword...
          However, renaming dit not change the result.
            loics
            So in the first post, I was trying reading data sent by the Pycom.
            I tried today to read data sent to the Pycom with the following code :
            uart=UART(1, 115200, bits=8, parity=None, stop=1, pins=('P3','P4'))
                if(uart.any()>0):
                    compteur += 1
                    print("INPUT : " + str(compteur) + " (" + str(uart.any()) + ")")
                    buf=uart.read()
                    print(buf)
            I have a sensor wich sends an ASCII string (18 bytes long) every second. I can read it with an USB->RS232 converter. However, On the pycom, I get the following "gibberish", every 4-5 seconds :
            INPUT : 9 (120)
            b'\x06\x06\xb4\x06d3yj\x06\x06\x06\xb4\x06\x0c\x19Z\r\x06\x06\x06\xb4\x06d3yj\x06\x06\x06\xb4\x06\x0c2Z\r\x06\x06\x06\xb4\x06dgyj\x06\x06\x06\xb4\x06\x0c\x19Z\r\x06\x06\x06\xb4\x06d3yj\x06\x06\x06\xb4\x06\x0c2Z\r\x06\x06\x06\xb4\x06d3yj\x06\x06\x06\xb4\x06\x0ceZ\r\x06\x06\x06\xb4\x06d\x19yj\x06\x06\x06\xb4\x06\x0c2Z\r\x06\x06\x06\xb4\x06d\x19yj\x06\x06\x06\xb4'
            INPUT : 10 (120)
            b'\x06\x0ceZ\r\x06\x06\x06\xb4\x06d\x19yj\x06\x06\x06\xb4\x06\x0ceZ\r\x06\x06\x06\xb4\x06d\x19yj\x06\x06\x06\xb4\x06\x0c2Z\r\x06\x06\x06\xb4\x06dfyj\x06\x06\x06\xb4\x06\x0c2Z\r\x06\x06\x06\xb4\x06d\x19yj\x06\x06\x06\xb4\x06\x0ceZ\r\x06\x06\x06\xb4\x06deyj\x06\x06\x06\xb4\x06\x0cfZ\r\x06\x06\x06\xb4\x06d2yj\x06\x06\x06\xb4\x06\x0c\x19Z\r\x06\x06\x06\xb4\x06de'
            The COM parameters are correct (115200, 8, None, 1). I connected the COM GND of my sensor to the GND of the Pycom.
            Does anyone has had a similar issue ? I can't find anything on the forum.
              loics
              Solved : turns out I needed a USB<->TTL and not an USB<->RS232...
              I did not know about the TTL standard, as I did not study eletronics at all. Gotta learn the hard way !
