    LoRa Communication Between FiPy and Adafruit Feather 32u4 Running RadioHead Library
    radioheadfeather 32u4
    4 Posts 3 Posters 47 Views 3 Watching
    • E Offline
      Edward
      I'm trying to receive the packets sent out from a Feather 32u4 using the RadioHead library on the FiPy; however, no matter what settings I try to adjust, I cannot seem to receive any of the packets sent by the feather. The feather uses a RFM95W. What I am trying to do is similar to this forum post from earlier (https://forum.pycom.io/topic/693/lopy-communication-with-rfm95-modules), where I am just trying to receive and read out the packets.
      Currently, I am stuck where I cannot receive the packets on the FiPy in the first place, and would greatly appreciate any help I could get.
      Here is the code on the FiPy:
      import struct
      from network import LoRa
      import gc
      LORA_MSG_FORMAT = "LLBBBBlB"
      class incoming_message:
          def __init__(self, data):
             self.control, self.deviceID, self.Seq, self.indicator1,  self.indicator2,  self.stype,  self.svalue,  self.check = struct.unpack(LORA_MSG_FORMAT, data)
      #self.control is something added from RFM95. Just discard it. Your message starts from the 5th byte
      class server:
          def __init__(self):
              cfg_mode = LoRa.LORA
              cfg_freq = 915000000
              cfg_bandwidth=LoRa.BW_125KHZ        # LoRa.BW_125KHZ or LoRa.BW_250KHZ
              cfg_sf = 7                          # Accepts values between 6 and 12.
                                                  #  6 =   64  Chips/Symbol
                                                  #  7 =  128  Chips/Symbol
                                                  #  8 =  256  Chips/Symbol
                                                  #  9 =  512  Chips/Symbol
                                                  # 10 = 1024  Chips/Symbol
                                                  # 11 = 2048  Chips/Symbol
                                                  # 12 = 4096  Chips/Symbol
              cfg_preamble=8                      #configures the number of pre-amble symbols. The default value is 8
              cfg_coding_rate=LoRa.CODING_4_5     #LoRa.CODING_4_5, LoRa.CODING_4_6, LoRa.CODING_4_7 or LoRa.CODING_4_8
              cfg_power_mode=LoRa.ALWAYS_ON       #LoRa.ALWAYS_ON, LoRa.TX_ONLY or LoRa.SLEEP
              self.lora = LoRa(mode=cfg_mode,
                frequency=cfg_freq,
                tx_power=14,
                bandwidth=cfg_bandwidth,
                sf=cfg_sf,
                preamble=cfg_preamble,
                coding_rate=cfg_coding_rate,
                power_mode=cfg_power_mode,
                tx_iq=False,
                rx_iq=False,
                public=False)
              self.lora.init(mode=cfg_mode,
                frequency=cfg_freq,
                tx_power=14,
                sf=cfg_sf,
                tx_iq=False,
                rx_iq=False,
                public=False)
              self.lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
              self.lora_sock.setblocking(False)
          def update(self):
              raw_data = self.lora_sock.recv(61)
              if raw_data:
                  try:
                      msg = incoming_message(raw_data)
                      if msg.deviceID % msg.Seq == msg.check:
                          print("msg received. devid:", msg.deviceID,  " seq:", msg.Seq)
                          print("msg check failed")
                  except:
                      print("msg failed to parse")
                  pass
      def test_server():
          srv = server()
              srv.update()
      test_server()
      And here is the code I am running on the Feather:
      #include <SPI.h>
      #include <RH_RF95.h>
      #define FREQUENCY  915.0
      struct tpayload {
         uint32_t deviceid;   //4
         byte seq;            //1
         byte indicator1;     //1
         byte indicator2;     //1
         byte stype;          //1
         long svalue;         //4
         byte check;          //1
      tpayload payload;
      RH_RF95 rf95(8,7);    // Chip Select=8, INT Pin = 7
      void setup() {
        Serial.begin(57600);
        while(!Serial);
        if (!rf95.init()) {
           Serial.println("init failed");
        if (!rf95.setFrequency(FREQUENCY)) {
          Serial.print("init freq failed");
        payload.seq = 0;
        payload.deviceid = 8512;
        payload.indicator1 = 1;
        payload.indicator1 = 2;
        payload.stype = 2;
        payload.svalue = -10;
      void loop() {
        payload.seq++;
        if (payload.seq == 0) payload.seq++;  // to avoid division by zero at the next line
        payload.check = payload.deviceid % payload.seq;  // you need this to discard corrupted messages
        uint16_t now = micros();
        rf95.send( (const void*)&payload, sizeof(payload));
        delay(5000);
      In the RadioHead Library I have edited in the matching modem config settings, so I am not quite sure what I am still missing. Again, I would greatly appreciate any help I could get!
        andreas @Edward
        • E Offline
          Edward
          I should probably clarify what I am trying to do a bit better:
          I am trying to use the code that constantinos and Clemens posted earlier, just to try to get a version that will receive packets from the feather in the first place. I looked through the forum for other posts and have tried tinkering with the different settings to no avail.
          Forgive me for any mistakes I am making, as I am new to this and trying to figure it out! Again, I would greatly appreciate any help I can get!
          • N Offline
            nowakowski912 Banned
