Modified Class to allow DS18B20 reading with different resolutions
I added write_scratch and read_temp to class.
read_temp uses the bit resolution values of 9 - 12 and incorporates the correct delay for data acquisition.How to use:
from machine import Pin from onewire import DS18X20 from onewire import OneWire ow = OneWire(Pin('P8')) temp = DS18X20(ow) while True: print(temp.read_temp(9)) print(temp.read_temp(10)) print(temp.read_temp(11)) print(temp.read_temp(12)) print("----------------")
Output:
23.5 23.25 23.125 22.9375 ----------------
The temperature was dropping hence the last reading is lower.
