    GPY with hologram SIM 2020
    2 Posts 2 Posters 83 Views 2 Watching
      colsen13
      Re: GPy with Hologram.io SIM
      I am trying to use a hologram sim with a GPY and am having no luck. I followed everything I could find in the forums but no changes.
      I have updated the firmware on the expansion board, GPY, and modem but still the same.
      I just bought the GPY but it is a V1.0. Are there problems with this version connecting to the Verizon network in the US using the hologram SIM?
      AT+CEREG? returns 2,0. My phone shows Verizon at full strength at my location and I can see the top of the cell tower from my test location.
      I have the LTE antenna attached.
        jbuck
        I too have a hologram SIM with GPy w/ the default LTE antenna, and at a time earlier in the year I was able to make connections to Vzw networks automatically (after calling attach, and hologram's dashboard just indicated it)
        i'm using modem version CATM1 41065 on "MicroPython v1.20.2.rc3-4-g4962aea3b-dirty"
        At the time of my post I see there is a 1.20.2.rc10 that might be worth a try for more stability... i'm uncertain what bugfixes may be present since then.
        I haven't been able to get it to connect automatically anymore but did notice that if you run
                send_at_cmd_pretty('AT!="showphy"')
                send_at_cmd_pretty('AT!="fsm"')
        and the modem doesn't say it is off, you can list the available networks found using 'AT+COPS=?'
        After which you can manually connect to the network with the command
        setnetwork(network="331480", mode="2")
        technically you could do it by an actual ascii network name but i did it by id as per
        https://m2msupport.net/m2msupport/atcops-plmn-selection/
        At any
        def send_at_cmd_pretty(cmd):
            response = lte.send_at_cmd(cmd).split('\r\n')
            for line in response:
                print(line)
        def getscannetworks():
            send_at_cmd_pretty('AT+COPS=?')
        def getattachednetwork():
            send_at_cmd_pretty('AT+COPS?')
        def getccid():
            send_at_cmd_pretty('AT+CCID')
        def getsig():
            send_at_cmd_pretty('AT+CSQ')
        def getCEREG():
            send_at_cmd_pretty('AT+CEREG?')
        def setnetwork(network="331480", mode="2"):
            # _,mode,network
            #0 automatic ( field is ignored)
            #1 manual ( field shall be present, and optionally)
            #2 deregister from network
            #3 set only (for read command +COPS?), do not attempt registration/deregistration ( and fields are ignored); this value is not applicable in read command response
            #4 manual/automatic ( field shall be present); if manual selection fails, automatic mode (=0) is entered
            #mode = 0 short alphanum, 1 long alphanum, 2 numeric
            send_at_cmd_pretty('AT+COPS=1,'+mode+',"'+network+'"')
