    uart write human-readable ASCII text
    9 Posts 5 Posters 150 Views 5 Watching
    • M Offline
      Mao
      I'm working on Lopy4 interfacing with Nextion serial display (http://nextion.tech/instruction-set/#s6).
      To send the data to the monitor for displaying, I have to follow their rules (see below Arduino code for instance).
      Sample code from https://www.youtube.com/watch?v=akpF9TbvNss&t=542s
      I had tried to migrate the Arduino code to Lopy4, but never make it works. After investigating, my understanding is that uart.write() can not accomplish the work that Serial.print()in Arduino does. Because the former write a series of bytes to the serial port, while the latter one prints human-readable ASCII text to the serial port.
      So my question is can Lopy4 UART port write human-readable ASCII text? Please give some instructions. Thank you!
      • M Offline
        Mao
        In short, can Lopy4 UART port performs the same function as Serial.print() does in Arduino?
        O 1 Reply Last reply Reply Quote 0
          johand
          Try:
          uart.write("Hello World!".encode())
          Not 100% sure, but thinks that should do the trick.
          Johan
            robert-hh @Mao
            @Mao There are two options:
            a) use the str() function or an string formatting methods to convert a non-ascii object into it's ascii representation, which you then can send with uart.write(). Like uart.write(str(100.3))
            b) use the file = stream option of print, like:
            from machine import UART
            uart = UART(1)
            print("The answer is", 42, ", but what is the question?", file=uart)
            Obviously you can combine both methods for a pretty formatted output, a little bit easier than you could do with Arduino.
            P.S.: Thanks to Dave Hylands pointing me at the file=xxx option again.
            • M Offline
              Mao
              Thank you for all the instruction and explanation! My problem finally got fixed!
              mogplus8M 1 Reply Last reply Reply Quote 0
              • mogplus8M Offline
                mogplus8 @Mao
                @Mao could you please post a copy of your program? I have not been able to find a way to send the 0xFFFFFF Nextion terminator to the Nextion screen as part of the uart.write command. It always complains that it can't convert the object to a string. If I try to convert it to a string it is converted to the string of characters that I used to define the object, like b'\xff\xff\xff' or 765. How did you do it?
                Thanks,
                • mogplus8M Offline
                  mogplus8 @mogplus8
                  @mao
                  Well I think I've solved this one. It seems the original method now works, although I will swear on a stack of Bibles that it didn't the first time I tried it. I set a variable to '\xff\xff\xff' and then use that as the command terminator and it now at least runs whereas I was getting an error message before.
                  Now I have a different problem...
                  • O Offline
                    oliverthom707
                    • O Offline
                      oliverthom707 @Mao
                      @Mao Thanks man issue is finally resolved.
