Tone generation using PWM
My routine is:
def Tone(Speaker, Frequency, Duration): pwm = PWM(0, frequency = Frequency) pwm = pwm.channel(0, pin=Speaker, duty_cycle = 0.5) sleep_ms(Duration)Calling it with:
Tone(Speaker, 800, 1000)How do I stop the Tone after the delay?
This routine on the Esp8266 worked:
def Tone(Speaker, Frequency, Duration): pwm = PWM(Pin(Speaker)) pwm.freq(Frequency) pwm.duty(500) sleep_ms(Duration) pwm.deinit() -
I'm answering my own query again but a workaround that I found is this:
def Tone(Speaker, Frequency, Duration): pwm = PWM(0, frequency = Frequency) pwm = pwm.channel(0, pin=Speaker, duty_cycle = 0.5) sleep_ms(Duration) pwm = PWM(0, frequency = 4000)Setting the PWM frequency to >3999Hz kills the output. Must be a more elegant way though.
Actually this is a better fix, the previous fix left the Speaker pin High and using power, this leaves it Low.
def Tone(Speaker, Frequency, Duration): pwm = PWM(0, frequency = Frequency) pwm = pwm.channel(0, pin=Speaker, duty_cycle = 0.5) sleep_ms(Duration) i = Pin(Speaker, mode=Pin.IN)I seem to be talking to myself a lot !!?? Anyone else around?
