    Upgrade Pygate firmware
    5 Posts 2 Posters 207 Views 2 Watching
    • papasmurphP Offline
      papasmurph
      Update: I collected the findings to a single post.
      I just got a Pygate with a WiPy as "host".
      The tutorial page at https://development.pycom.io/tutorials/all/pygate/ says "Flash the Pycom Device with a firmware build where Pygate functionality is enabled."
      I used the tool at https://docs.pycom.io/gettingstarted/installation/firmwaretool/ and upgraded using "pygate" and "pybytes".
      "pygate" caused the WiPy to not start at all.
      "pybytes" restored the function to what it was before (seemingly).
      I installed the Pygate tutorial example as-is, except for fixing the indentations and changing the WiFi configuration and also adapted config.json to my needs.
      Both before and after upgrade I get "AttributeError: 'module' object has no attribute 'callback'" for machine.callback, so it seems Pygate functionality is still not there.
      Is there anything else I should do?
      Thanks in advance.
      papasmurphP 2 Replies Last reply Reply Quote 0
        papasmurph @papasmurph
        papasmurphP 1 Reply Last reply Reply Quote 0
            This was solved by checking "Include development software".
            Also, I thought the WiPy3 supported 5 GHz. That's not mentioned on the product page.
            Now I have data arriving at TTN via WiFi.
            • B Offline
              bgeorges @papasmurph
              @papasmurph I just ran into the same issue even though I checked the "include development Software" and I had the boards (patate and WiPy) already setup and running before I did the upgrade. I tried to clear the user space as well and go through a clean build but still stuck. I am stuck with the same error :
              Starting LoRaWAN concentrator
                File "main.py", line 26, in <module>
              Pycom MicroPython 1.20.2.r0 [v1.11-783192e] on 2020-08-06; WiPy with ESP32
              Pybytes Version: 1.5.1
              Anyone faced this issue ?
