    LoRa nano gateway slower throughput
    3 Posts 2 Posters 74 Views 2 Watching
    • B Offline
      Bhavit
      I am using lorawan nano gateway example, where 1st lopy4 is programmed as a nano gateway and 2nd device as node via ABP.
      I am trying to send 50 packets of 50 bytes.
      These packets are received by the gateway at every 3 seconds interval because of that I am getting only 16.6 Bytes/s throughput.
      How can I get maximum possible throughput using SF7, BW125, CODING_4_5, Region=IN865, mode= lorawan....?
        robert-hh @Bhavit
        @Bhavit I would assume that the speed is limited by the node, not the gateway. The node cannot send packets faster than once per about 2 seconds in LoRaWAN mode A. After sending a packet, if wait two seconds for possible downlink messages.
        • B Offline
          Bhavit @robert-hh
          @robert-hh So if I'll program that node as Class C then is it possible that I can get better throughput ?
