    Guide/Tutorial/Reference about Expansion Board
    13 Posts 4 Posters 387 Views 5 Watching
    • rcolisteteR Offline
      rcolistete
      Here is a long guide/tutorial/reference about all Expansion Board models :
      • "Using Expansion Board" in english;
      • "Usando Expansion Board", em brazilian portuguese.
      Thanks to Ricardo Retsos.
      "Using Expansion Board" has :
      • hints & tips collected from some years of experience, Pycom forum, etc;
      • detailed descriptions of features, mini-jumpers, etc;
      • list of documentation from Pycom and community;
      • many comparisons between the Expansion Board models;
      • tutorial about installing firmware on Expansion Board v3.x;
      • example source code to access user LED, user button, microSD slot, read battery voltage, etc;
      • energy consumption measurements of all Expansion Board models in active/light sleep/deep sleep, with USB power supply and battery power;
      • voltage measurements with USB power supply and battery power.
      For example, tests with Expansion Board v3.1 with WiPy3 in :
      • deep sleep mode, power from battery (Vbat = 3,61-3,66 V) :
        • 34 uA with only TX/RX mini-jumpers;
        • 102 uA with all mini-jumpers;
        • 183 uA with 8GB Sandisk UHS-I uSD and all mini-jumpers;
        • 160 uA with 16GB Toshiba M203 UHS-I uSD and all mini-jumpers;
        • 692 uA with 32GB Samsung Evo UHS-I uSD and all mini-jumpers.
          So :
        • the LED mini-jumpers adds 68 uA;
        • microSD card, just inserted, adds 58-590 uA, depending on the uSD card (not only the capacity).
      • active mode, it seems a 'feature' (or bug ?) when using TX/RX mini-jumpers and battery supply (3.61-3.66 V) :
        • 34.5-35.0 ma without mini-jumpers;
        • 68.8-69.4 ma with only TX/RX mini-jumpers
        • 69.6-70.2 ma will all mini-jumpers.
          This is a 33.8-34.9 mA increase.
          But when using USB power (Vusb = 5.06-5.08 V), this issue doesn't happen, i = 43-44 mA with any mini-jumpers configuration.
      P 2 Replies Last reply Reply Quote 2
        PSH_IS_NIVA @rcolistete
        Thanks for a great work...
        Does anyone have information about version 3.2?
        The jumper set has changed to 6 instead of 7: "RTS" and "CTS" are gone and a new one "RUN" is introduced.
          PSH_IS_NIVA @PSH_IS_NIVA
          On my Expansion board V3.2 the battery voltage divider seems to divide to about 60% of the battery voltage.
          E.g. if the battery voltage is 3,6V then the voltage measured on the batt or P16 is about 2.1V. I checked this with a mulitmeter.
          rcolisteteR 1 Reply Last reply Reply Quote 1
            rcolistete @PSH_IS_NIVA
            @PSH_IS_NIVA I don't have an Expansion Board v3.2, but I ordered one.
            Tip : check without xxPy board connected to Expansion Board, disconnected from USB/battery power, so you can measure with the ohmmeter the 2 resistors of the voltage divider.
            So, please, any information about the voltage divider or other differences in Expansion Board v3.2, feel free to share.
            I don't find any Pycom documentation about Expansion Board v3.2 and its different features.
              @rcolistete
              Hmm this is confusing :/
              After I read your suggestion I thought I made a mistake because I measured the voltages with also USB power connected... but then again is this really the wrong way to do it?? Well I'd say: here comes in play the lack of documentation from Pycom.... as mentioned many many times by several people in this forum :(
              Anyhow...my assumption is that the divider is like this:
              But that does not fit the following observations:
              • With the expansion board empty and disconnected i.e. no xxPy, no battery, no USB and no BAT-jumper, I can measure R2 ( BAT-jumper <-> GND) to 0.94 Mohm but I can't measure R1 (+pin JST <-> BAT-jumper). The R1 value is not stable. My meter starts at about 2.5 Mohm but increases slowly to 2.9ish.
              • With only a battery (3.6V) connected, no XXPy and no USB and no BAT-jumper I measure Vbat (+pin JST <-> GND) to 3.6V and V_R2 (BAT jumper <-> GND) to about 1.8V
              • as above but with USB-power added: Vbat still 3.6V and V_R2 is now about 2.1V.
                robert-hh @PSH_IS_NIVA
                @PSH_IS_NIVA With USB connected the battery will be charged. That's why the voltage at VBat should go up.
                  PSH_IS_NIVA @robert-hh
                  @robert-hh said in Guide/Tutorial/Reference about Expansion Board:
                  No it didn't. Vbat (+pin JST <-> GND) was stable on 3.6V with or without USB connected.
                  • K Offline
                    kjm
                    In 'Using Expansion Board' in English you state "when using FiPy or GPy with Expansion Board, remove the RTS and CTS mini-jumpers, as they conflict with the operation of the LTE modem, see CAT-M1 and NB-IoT tutorials:
                    1. I run a gpy on expansion board 2.0 with the RTS/CTS jumpers in place & no problems with the lte modem.
                    2. The clickable link to CAT-M1 doesn't seem to provide any useful detail on RTS/CTS
                    I'm not being critical, indeed I think any attempt to clarify pycoms chaotic documentation is laudable. But I'm still no wiser! I can't even figure out which uart the RTS/CTS jumpers apply to. Is it the uart that services the usb port or the uart that services the lte modem.
                    rcolisteteR 1 Reply Last reply Reply Quote 0
                      FYI, pictures top/bottom expansion boards v3.2:
                        @PSH_IS_NIVA It seems that Expansion Board v3.2 is for a specific customer, not a public release. But it was shipped by mistake to some users.
                          @rcolistete said in Guide/Tutorial/Reference about Expansion Board:
                          @rcolistete:
                          Well, you may be right. As you can see from my last post here I'm of the opinion that it was just the firmware on the boards that was a incorrect version. But rereading some of correspondence - also directly with Pycom Support I'm not 100% sure any more. Only Pycom can confirm this I suppose.
                          Though, whether or not it is just the firmware or the hole board, our problem was fixed with just an firmware update.
                            See this post :
                            "@PSH_IS_NIVA We accidentally shipped a number of Expansion Board 3.2 that were designed for a specific customer.
                            Anyone who received an Expansion Board 3.2 please email support@pycom.io so we can provide a resolution."
                              rcolistete @kjm
                              @kjm said in Guide/Tutorial/Reference about Expansion Board:
                              My test with FiPy (old one) had problems with RTS/CTS jumpers, so the recommendation is correct. But I don't have GPy to confirm if the Pycom recommendation isn't needed for GPy.
