    Pytrack 2.0X and GPy not detected on Atom
    3 Posts 2 Posters 102 Views 2 Watching
      Akul9092
      I am using a MacBook Air 2018 and I connected my Module (pytrack 2.0x and gpy) using a micro usb cable and usb to usb c adapter. However, when I launch Atom, it says that no device is connected. Funnily enough, there is a heartbeat on the module (blue light flickering) and I can run files using the wifi function but it is quite inconvenient. I verified that its not the port as I used an Arduino and nor is it the cable as I tried a different one. Any solution?
        Make sure your USB cable setup also passes through communication, not just power. It is common for USB micro to USB C adapters to just pass power and not data. Im not 100% sure whether the setup would work at all and if other USB C conductors are used..
        If this is not the issue, you can check whether the board is recognized using lsusb in the terminal. It should show a Pygate device.
        Let me know!
        A 1 Reply Last reply Reply Quote 2
          Akul9092 @Gijs
          @Gijs Hi, thanks a lot! I wasn't aware that certain micro-usb cables are like that. After some searching, I found one cable that worked. Thanks again!
