SiPy firmware update tool now available with ID and PAC for activation
Hello everyone,
I'm pleased to announce that we have a new updater tool available which now supports the SiPy. It will allow you to do 2 things:
- Update the SiPy to the latest firmware released (1.5.0.b2)
- Flash a Sigfox ID, PAC and Keys for use of the module straight away on any Sigfox networks.
Please be careful when selecting the module type (WiPy 2.0, LoPy or SiPy) and the Sigfox zone, as these settings will be stored permanently in our servers (therefore after the first time the board is recognised, it is flashed automatically with the firmware version that belongs to it). If you make a mistake we can still reverse it but you are going to have to send an email to support-at-pycom.io. The updater tool can be downloaded from:
https://www.pycom.io/support/supportdownloads#firmware
It is necessary to download the new tool, as the previous one doesn't support the SiPy
After flashing the SiPy, the tool will show the ID and the PAC, these details can also be retrieved via the Sigfox class on the board. You will need to take note of those 2 hexadecimal numbers and then go to the Sigfox activation portal to get a free developer account on the Sigfox back-end.
Follow this link to Activate your SiPy: https://backend.sigfox.com/activate/pycom
For more details around activation check the docs: https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/sigfox-start.html
And also make sure to read the Sigfox API documentation: https://docs.pycom.io/pycom_esp32/library/network.Sigfox.html
Cheers,
Daniel -
@daniel Great work guys! I know you have worked through the weekend for this result. I can also confirm the SiPy modules in the UK have been flashed and working perfectly on the Sigfox network!
So I rushed to https://www.pycom.io/support/supportdownloads
and..."We'll be right back"
😩ðŸ˜ðŸ˜©ðŸ˜ðŸ˜©ðŸ˜ðŸ˜©ðŸ˜ðŸ˜©ðŸ˜ðŸ˜©ðŸ˜ðŸ˜©ðŸ˜
@jmarcelino Sorry.... we are upgrading a module on the website. We had to take it down... 5 minutes max :)
Thanks it really was just 5 minutes!
Nice going!
Unfortunately the linux tool seems to be the old one without support for SiPy :'(
I don't have any windows machine so I can't upgrade the firmware.
Any solutions? -
@sybrenromer unfortunately there's no solution besides waiting for the unix tool which should be available soon (probably tomorrow end of the day). We can't provide a manual way to update the SiPy's...
Apologies for the delay on this, we focused on the Windows and OS X tool as that is what 99% of the community is using.
Cheers,
Daniek -
where do i find my ID and PAC?
@daniel No problem, thanks for letting me know :)
Will try it as soon as the new tool is available!By the way is it normal the pycom is still reachable in update mode? I've connected pin 23 to GND but the heartbeat is still there and I can also still connect..
@iotmaker the updater tool will show you the ID and PAC after flashing the SiPy. Besides that, you can always get it from the board by using the Sigfox class API. Please check the link about the activation procedure which explains all the steps.
@sybrenromer yes that's normal. To enter update mode you have to reset the board after connecting G23 to GND.
@daniel I've tried, but there is no way to get the SiPy in update mode. I'm currently using a friends PC and the updater tool says the connection failed after trying for about 5 seconds.
Is there something else I could be doing wrong?I don't have the expansion board (yet) but have connected the serial cable through a breadboard to my SiPy as it sais in the documentation.
It should be ok with any usb to serial converter. Please email me a picture of your setup and connections to support-at-pycom.io and I'll have a look right now. I think you are confusing pin 23 (it's actually G23 as marked on the expansion board, which equals to P2 on the module), it's the fourth pin from top to bottom on the left row.
Cheers,
Daniel -
@daniel Ah that was my mistake then x) It seems to work fine now with the update mode, but the updater still fails. I think this might have something to do with the windows serial port, so maybe I should wait for the linux updater and try that first before bothering you guys with it :)
Cheers,
Sybren -
Updated my SiPy, registered with Sigfox backend and also tested with Sigfox network emulator. All working fine! Thanks for the many hours poured into this :)
@jmarcelino thanks for the positive feedback :-)
Can't seem to update my SiPy?
I connect the GND to G23 and then plug in the usb.
Then I start up the updater and choose the correct port but I get this message:
Result
The upgrade failed, please check the connections and try these steps again.
This is the log of the upgrading process:
Connecting.................................
Failure! -
@sk could you please try to upload the message screenshot again? Thanks...
@daniel
...Its not uploading -
@daniel said in SiPy firmware update tool now available with ID and PAC for activation:
In the downloads page the firmware for the updater is 1.0.0.b1.
Is this the correct one?
Also I can't upload or paste any files/images because "Error. You do not have enough privileges for this action."
