    Pygate -- LORA Antenna Connection w/ LoPy4?
    4 Posts 2 Posters 100 Views 2 Watching
      piez
      Hey all,
      Just want to confirm (before I fry a LoPy4!) that Pygate only needs a LoRa antenna connected to port on the Pygate board -- when used with a LoPy4? I.e. no antennas need connecting directly to the LoPy4?
      Scoured the docs -- but I can't see this mentioned.
      Thx
      Sam
        @piez said in Pygate -- LORA Antenna Connection w/ LoPy4?:
        True, when using the Pygate, you only need to add the antenna to the Pygate board as the LoRa radio of the Lopy4 is not in use!
        Thanks, I will try to make this more clear in the docs (where did you look first, would be interesting to know :) )
        Best
        P 1 Reply Last reply Reply Quote 1
          piez
            piez @Gijs
            @Gijs
            Awesome -- thanks for confirming.
            In order -- I checked
            https://docs.pycom.io/tutorials/pygate/ first
            https://docs.pycom.io/datasheets/boards/pygate/
            https://docs.pycom.io/gitbook/assets/specsheets/Pycom_002_Specsheets_Pygate_v1.pdf
            Perhaps a adding a note in the blue box on https://docs.pycom.io/tutorials/pygate/ when LoPy4 is mentioned makes sense?
