Guru Meditation Error: Core 0 panic'ed (LoadProhibited)
I am running a FiPy with version 1.20.2.rc9. My code is reading messages over LoRa at about 1 per sec and then publishing the data to an MQTT broker at the same rate. Everything will be running fine and then at some random time interval my FiPy will crash. It might run for a few hours or only a few minutes. This particular test ran for about 22 minutes before crashing. I have try/except statements around a lot of code to see if I can catch some other error but nothing. This is the latest core dump.
=============================================================== ==================== ESP32 CORE DUMP START ==================== ================== CURRENT THREAD REGISTERS =================== pc 0x4018c7f5 0x4018c7f5 <ip4_input+37> lbeg 0x40093378 1074344824 lend 0x400933a6 1074344870 lcount 0xffffffff 4294967295 sar 0x18 24 ps 0x60f20 397088 threadptr <unavailable> br <unavailable> scompare1 <unavailable> acclo <unavailable> acchi <unavailable> m0 <unavailable> m1 <unavailable> m2 <unavailable> m3 <unavailable> expstate <unavailable> f64r_lo <unavailable> f64r_hi <unavailable> f64s <unavailable> fcr <unavailable> fsr <unavailable> a0 0x40190c74 1075383412 a1 0x3ffbaee0 1073458912 a2 0x3fbc2750 1069295440 a3 0x3ffe5740 1073633088 a4 0x2800 10240 a5 0x450 1104 a6 0x3fbc39d2 1069300178 a7 0x45 69 a8 0x80183be3 -2145895453 a9 0x3ffbaed0 1073458896 a10 0x0 0 a11 0x1002e 65582 a12 0x0 0 a13 0x0 0 a14 0x3ffb9f38 1073454904 a15 0x1 1 ==================== CURRENT THREAD STACK ===================== #0 ip4_input (p=0x3fbc2750, inp=0x3ffe5740) at /Users/ehlers/pycom/pycom-esp-idf/components/lwip/lwip/src/core/ipv4/ip4.c:473 #1 0x40190c74 in ethernet_input (p=0x3fbc2750, netif=0x3ffe5740) at /Users/ehlers/pycom/pycom-esp-idf/components/lwip/lwip/src/netif/ethernet.c:184 #2 0x40181de4 in tcpip_thread (arg=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/lwip/lwip/src/api/tcpip.c:135 ======================== THREADS INFO ========================= Id Target Id Frame * 1 <main task> ip4_input (p=0x3fbc2750, inp=0x3ffe5740) at /Users/ehlers/pycom/pycom-esp-idf/components/lwip/lwip/src/core/ipv4/ip4.c:473 2 process 1 0x4021fc76 in esp_pm_impl_waiti () at /Users/ehlers/pycom/pycom-esp-idf/components/esp32/pm_esp32.c:492 3 process 2 0x4021fc76 in esp_pm_impl_waiti () at /Users/ehlers/pycom/pycom-esp-idf/components/esp32/pm_esp32.c:492 4 process 3 0x40096b02 in vTaskDelay (xTicksToDelay=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/tasks.c:1484 5 process 4 0x40096b02 in vTaskDelay (xTicksToDelay=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/tasks.c:1484 6 process 5 0x40096b02 in vTaskDelay (xTicksToDelay=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/tasks.c:1484 7 process 6 0x4000bff0 in ?? () 8 process 7 0x40096b02 in vTaskDelay (xTicksToDelay=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/tasks.c:1484 9 process 8 0x40096b02 in vTaskDelay (xTicksToDelay=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/tasks.c:1484 10 process 9 0x40096b02 in vTaskDelay (xTicksToDelay=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/tasks.c:1484 11 process 10 0x40096b02 in vTaskDelay (xTicksToDelay=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/tasks.c:1484 12 process 11 0x40097ce9 in prvProcessTimerOrBlockTask (xListWasEmpty=1, xNextExpireTime=<optimized out>) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/timers.c:589 13 process 12 0x4000bff0 in ?? () 14 process 13 0x40095d08 in xQueueGenericReceive (xQueue=0x3ffe3cc0, pvBuffer=0x3ffd51c4, xTicksToWait=4294967295, xJustPeeking=0) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/queue.c:1592 15 process 14 0x40095d08 in xQueueGenericReceive (xQueue=0x3ffb7bd8, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/queue.c:1592 16 process 15 0x40095d08 in xQueueGenericReceive (xQueue=0x3ffda03c, pvBuffer=0x3ffdb1e0, xTicksToWait=4294967295, xJustPeeking=0) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/queue.c:1592 17 process 16 0x40095d08 in xQueueGenericReceive (xQueue=0x3ffb760c, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/queue.c:1592 18 process 17 0x40081620 in esp_crosscore_int_send_yield (core_id=0) at /Users/ehlers/pycom/pycom-esp-idf/components/esp32/crosscore_int.c:112 19 process 18 0x40095d08 in xQueueGenericReceive (xQueue=0x3ffb3c28, pvBuffer=0x3ffb5a10, xTicksToWait=4294967295, xJustPeeking=0) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/queue.c:1592 20 process 19 0x40095d08 in xQueueGenericReceive (xQueue=0x3ffbd718, pvBuffer=0x3ffe23a0, xTicksToWait=4294967295, xJustPeeking=0) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/queue.c:1592 21 process 20 0x40095d08 in xQueueGenericReceive (xQueue=0x3ffd53d8, pvBuffer=0x3ffd67d0, xTicksToWait=4294967295, xJustPeeking=0) at /Users/ehlers/pycom/pycom-esp-idf/components/freertos/queue.c:1592 22 process 21 0x4000bff0 in ?? () ======================= ALL MEMORY REGIONS ======================== Name Address Size Attrs .rtc.text 0x400c0000 0x64 R XA .rtc.data 0x50000000 0x81c RW A .rtc_noinit 0x5000081c 0x0 RW .rtc.force_slow 0x5000081c 0x0 RW .iram0.vectors 0x40080000 0x400 R XA .iram0.text 0x40080400 0x18824 R XA .dram0.data 0x3ffbdb60 0x4950 RW A .noinit 0x3ffc24b0 0x0 RW .flash.rodata 0x3f400020 0x5e69c RW A .flash.text 0x400d0018 0x152ed0 R XA .coredump.tasks.data 0x3ffb9fb4 0x16c RW .coredump.tasks.data 0x3ffbae20 0x1a4 RW .coredump.tasks.data 0x3ffbbeb4 0x16c RW .coredump.tasks.data 0x3ffbbd10 0x19c RW .coredump.tasks.data 0x3ffbb940 0x16c RW .coredump.tasks.data 0x3ffbb7a0 0x198 RW .coredump.tasks.data 0x3ffb4d38 0x16c RW .coredump.tasks.data 0x3ffb4b40 0x1f0 RW .coredump.tasks.data 0x3ffdfb80 0x16c RW .coredump.tasks.data 0x3ffd48e0 0x170 RW .coredump.tasks.data 0x3ffbd5a8 0x16c RW .coredump.tasks.data 0x3ffdd130 0x168 RW .coredump.tasks.data 0x3ffc45dc 0x16c RW .coredump.tasks.data 0x3ffd9a40 0x5f4 RW .coredump.tasks.data 0x3ffed028 0x16c RW .coredump.tasks.data 0x3ffeed80 0x414 RW .coredump.tasks.data 0x3ffe8bcc 0x16c RW .coredump.tasks.data 0x3ffea970 0x3c8 RW .coredump.tasks.data 0x3ffead40 0x16c RW .coredump.tasks.data 0x3ffecae0 0x3cc RW .coredump.tasks.data 0x3ffb5e74 0x16c RW .coredump.tasks.data 0x3ffd3c40 0x20c RW .coredump.tasks.data 0x3ffbcb20 0x16c RW .coredump.tasks.data 0x3ffbc9c0 0x158 RW .coredump.tasks.data 0x3ffbd870 0x16c RW .coredump.tasks.data 0x3ffde100 0x19c RW .coredump.tasks.data 0x3ffd525c 0x16c RW .coredump.tasks.data 0x3ffd5090 0x1c4 RW .coredump.tasks.data 0x3ffb7c30 0x16c RW .coredump.tasks.data 0x3ffb9cb0 0x188 RW .coredump.tasks.data 0x3ffbb0a4 0x16c RW .coredump.tasks.data 0x3ffdb0e0 0x1b0 RW .coredump.tasks.data 0x3ffb7a68 0x16c RW .coredump.tasks.data 0x3ffb78e0 0x180 RW .coredump.tasks.data 0x3ffb727c 0x16c RW .coredump.tasks.data 0x3ffb70c0 0x1b4 RW .coredump.tasks.data 0x3ffb5aac 0x16c RW .coredump.tasks.data 0x3ffb5910 0x194 RW .coredump.tasks.data 0x3ffde644 0x16c RW .coredump.tasks.data 0x3ffe2240 0x218 RW .coredump.tasks.data 0x3ffd6874 0x16c RW .coredump.tasks.data 0x3ffd66a0 0x1cc RW .coredump.tasks.data 0x3ffbb31c 0x16c RW .coredump.tasks.data 0x3ffdc100 0x194 RW ===================== ESP32 CORE DUMP END ===================== ===============================================================It looks like something is going wrong in the tcpip_thread. Can anybody give me any more insight into what might be going on?
