Using the gpy with no antenna?
Hello, we plan to connect these via lte at some point, but we aren't there yet. So I was wondering if it would harm the gpy to provision the unit without the antenna. Assuming we don't call LTE.attach() or any LTE functionality until after we attach the antenna, of course.
Any help or advice would be greatly appreciated!
@VST-Admin As long as you do not use the LTE device, you do not need an antenna. Be careful about pybytes. If that is used, it may try to use LTE.
