LoPy Pybytes - LoRa OTAA Connection Failed
I've successfully registered my LoPy device to the Pybytes platform. It is set up to connect via Wifi and LoRa OTAA. It successfully connects to Pybytes via Wifi when started. When I disconnect the device with pybytes.disconnect() and try to reconnect just to LoRa with pybytes.connect_lora_otaa(timeout=60, nanogateway=False), I get the following error:
>>> pybytes.disconnect() Watchdog timeout has been increased to 2147483647 ms >>> pybytes.connect_lora_otaa(timeout=15, nanogateway=False) Trying to join LoRa.OTAA for 15 seconds... Setting up LoRa socket... False >>>Does anyone have any advice?
@cromagnon Do you have any LoRa gateway in the area, like less than 2 km away?
Yes, I have a gateway set up to TTN that works in the same room
