    Socket Help
    socketwifilte nb iotudphelp
    10 Posts 3 Posters 230 Views 4 Watching
      ChadOvarro
      Good Morning,
      I am every new to using devices for embedded networking. I'm a lot more used to developing software for the cloud. I'm trying to create a very simple socket that sends a UDP packet that has been ascii encoded.
      Here is the code I'm using:
      import ssl
      print('stating script')
      UDP_Server = '<machine IP>'
      UDP_Port = 11000
      Message = 'Hello World!'
      eMessage = Message.encode('ascii')
      print(eMessage)
      s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
      print('socket created')
      s = ssl.wrap_socket(s)
      s.setblocking(False)
      s.connect(socket.getaddrinfo(UDP_Server, UDP_Port)[0][-1])
      print('socket connect set up')
      s.send(eMessage)
      print('message sent though socket')
      s.close()
      print('socket closed')
      The boards is setup to automatically connect to my wifi
      I have two issues i'm struggling with at the moment, and I'm hoping someone would kindly offer some help.
      1. When I run the script its prints messages to the console up to 'socket created' after that I don't get any more console statements and I have to turn the device on/off to get it to connect and work again. I belive the script is finishing to some extent due to my next issue.
      2. When a message gets to my UDP listener it received the message are 'garbage'. I know my listener works as I have successfully sent and decoded packs from both my pc and laptop. With such a simple script I can see what going wrong to cause this issue. Below is an image from my LTE test script, the left terminal is the one connected to the PyCom and the right is the one connected to my server.
      And here is the same image for the code snippet at the top of the post using my WiFi:
      The issues happen with Wifi and LTE (NB-IoT). Any help offered would be really appreciated.
        I am not exactly sure where you got the Message.encode('ascii') from?
        You should be able to use s.send('Hello World!') by default.
        If the server is local, you should also be able to connect using s.connect(('ip', port))
        Let me know
          ChadOvarro
          @Gijs
          Message.encode('ascii') is just from the standard library. Its a method on str object in CPython. Also to ensure compatibility across systems is it not good practice to explicitly encode message in a fixed format?
          Either way thanks for the suggestion!
          I tried, its doing the same thing, sending garbage to my listener.
            crumble @ChadOvarro
            @ChadOvarro
            You code in MICRO- nt C-pthon. Please have a look on the micropythonn documentation about the differences. Than have a look on the implementation details of pycom.
            There are differences which are important, if you which to write fast and stable code for these little devices. Writing code like you do it on a PC will work only for very small projects. If your stuff grows, you will run into problems - more sooner than later.
            If you are on a device with 2MB free memory instead of 32-64k, you may run later into problems. But later it will much harder to refactor the whole architecture.
            The micropython part is easy, There are chapters about the difference between CPython and microython and one about performance.
              ChadOvarro @crumble
              @crumble
              I know I'm writing in Micropython and not CPython. I have read the documentation. I have been writing code for hobby dev boards and micro controllers for about 9 years. I know the limitations of a micro controller. I know how to write embedded code.
              I need to know why my fipy is sending out garbage when everything else does not. If this does not work then I need to return by fipy's as i bought them to be mocking devices to speed up development of cloud services at work.
                I am not sure of the issue, but I believe it is with your server. When I run this example (from a quick google search: https://gist.github.com/majek/1763628) on my computer:
                udpserver.py
                import logging
                log = logging.getLogger('udp_server')
                def udp_server(host='0.0.0.0', port=1234):
                    s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
                    log.info("Listening on udp %s:%s" % (host, port))
                    s.bind((host, port))
                        (data, addr) = s.recvfrom(128*1024)
                        yield data
                FORMAT_CONS = '%(asctime)s %(name)-12s %(levelname)8s\t%(message)s'
                logging.basicConfig(level=logging.DEBUG, format=FORMAT_CONS)
                for data in udp_server():
                    log.debug("%r" % (data,))
                And this on my Lopy4:
                main.py
                from network import WLAN
                machine.idle()
                wlan = WLAN()
                wlan.init(mode=WLAN.STA, ssid="-", auth=(WLAN.WPA2, "-"))
                print("connecting..", end='')
                while not wlan.isconnected():
                    print(".", end='')
                s.connect(('ipaddr', 1234))
                s.send("hello world")
                print(s.recv(16))
                s.close()
                It works without issues and the response is:
                2020-07-30 11:43:45,465 udp_server       INFO	Listening on udp 0.0.0.0:1234
                2020-07-30 11:44:39,985 udp_server      DEBUG	b'hello world'
                and
                connecting....socket created
                b''
                socket closed
                I can even make it talk both ways (not setup here)
                Best,
                  ChadOvarro
                  The issue is not with my server. My server it works as expected:
                    I am not sure what exactly is going on in your UDP server setup, which is why I attached one. were you able to test the examples I send you?
                    There should not be any issue in either case, but can you test it anyways? I have also tried with sending things over http in my browser and that works fine as well ( https://docs.pycom.io/tutorials/networkprotocols/webserver/ )
                    Best,
                      ChadOvarro @Gijs
                      @Gijs
                      Ok...We got there in the end! Thank you for your help.
                      The issue was this line s = ssl.wrap_socket(s). Once this was removed it worked. Very annoyed at my self that I missed that. Hopefully this will help someone else out.
                        It can happen to the best of us! I missed the ssl line in your example as well when typing it over.
                        Great to hear it got solved
