New firmware release, version 1.5.1.b1 (supporting the SiPy)
Hi @daniel ,
Just now i downloaded the updater tool 1.0.0.b1 to upgrade the firmware for the FTP bug fix and when i ran the updater tool against my Lopy,i am getting the following error,
It looks like some JSON problem..Traceback (most recent call last): File "lopyupdate.py", line 96, in __after callback(result, param) File "lopyupdate.py", line 136, in <lambda> return self.get_file(key, True, lambda res, req: callback(BytesIO(res))) File "lopyupdate.py", line 331, in __firmwareDownloadCompleted self.__firmwareScript = load_tar(result) File "lopyupdate.py", line 58, in load_tar script = json.load(tar.extractfile("script")) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\__init__.py", line 291, in load **kw) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\__init__.py", line 339, in loads return _default_decoder.decode(s) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\decoder.py", line 364, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\decoder.py", line 382, in raw_decode raise ValueError("No JSON object could be decoded") ValueError: No JSON object could be decoded
Thanks & regards,
MK HB
Thanks for the new firmware. I understand that you really want to catch up sigfox but the real IoT stays on batteries. And batteries rely on deepSleep. I also understand that deepsleep's delay root cause is esspresif but at least inform us.
Thanks in advance
@TravisT Thanks! I'll get that fixed now.
Just as a note, the download section for the update tool description is out of date
"Current firmware updater version: 1.0.0.b1."
21 out of 24
