Detecting charge state
  • Not looking to get the battery percentage but but if the LED on the expansion board can tell if the battery is charged or charging can this be queried from a wipy or whatever?
  • @kiltedpython said in Detecting charge state:
    You can tell the battery is charging by the red LED on the expansionboard. Once the LED turns off, the battery is charged. This is not directly broken out to a controller pin, but can be easily connected as @robert-hh suggested, by connecting the LED to one of the GPIO pins (make sure you watch the voltage!)
  • @kiltedpython The led is connected to the charging IC. Lacking and information about the expansion board I cannot tell, if there is a software means to tell the state. You should be to connect the output of that pin (the led contact) to one of the GPIO pins of the WiPy with a thin wire.
