    Help a pycom newbie, please.
    4 Posts 2 Posters 48 Views 2 Watching
      gradighieri
      Hi everyone. I am having the exact same problem as described in the post below. I have main.py blinking the rgb led using "run". I added the code as described to boot.py. I can upload them but main.py does not run. Screenshot of Atom below. The only thing I've noticed is that boot.py and main.py are showing as "0kb". Did I not setup the project correctly?
      Re: How do I get main.py to run when the WiPy board boots?
        The main.py will automatically run after the boot.py, even without any content in the boot.py. Im not sure about the situation in 2018, but that is not at hand anymore.
        The files are marked as 0kb, as their size is rounded to 0. Im not sure of the content of your main.py file, but it should be running..
        Check the getting started for a working example
        Best, Gijs
          gradighieri @Gijs
          @Gijs
          Got it working. Something strange about how main.py was saved on my computer. Thanks!
            Ah yes, I forgot to mention, always save your project files before uploading, as unsaved changes will Not get uploaded
