Need help upgrading modem firmware
When I print sqnsupgrade.info() I get:
UE5.1.0.0f
LR5.1.1.0-46470Which option am I supposed to pick to upgrade the firmware for CAT-M1, since 46470 doesn't appear (and seems to be newer than the one I'm supposedly supposed to upgrade to).
CATM1-41065.dup
updater.elf
upgdiff_33080-to-41065.dup
upgdiff_39529-to-41065.dup
upgdiff_41019-to-41065.dup -
We are currently shipping modems with newer firmware than we have available.
FIY, your modem is already a CAT-M1 firmware (LR5.xx) so you do not need to update it. If you do wish to update it, do not use theupgdifffiles, as the none of the old versions match with what you currently have, you can only do a full upgrade using theCATM1-41064.dupfile.
Best,
