    PyGate with LoPY4 - High Power Consumption on Deep Sleep
    13 Posts 4 Posters 191 Views 5 Watching
      anikolaid
      Hi guys!
      I have the following setup:
      1. PyGate board powered only by a LiPO battery (3.6 Volt). USB-C port is not connected at all.
      2. LoPY4 running firmware 1.20.2.rc10.
      3. A LoRA antenna connected to PyGate.
      4. The example script from the documentation:
        https://docs.pycom.io/tutorials/expansionboards/pygate/#pygate
      I did the following measurements:
      1. When PyGate is running the power consumption varies from 100 to 400 mA (at 3.6 V external power). That is a normal power consumption for a GW that is connected to the Wi-Fi and receives-forwards LoRA messages to the TTN
      2. However, what is really strange is that the whole system (LoPY+PyGate) continues to consume 10mA once I put it in deep sleep - This is how I do it: I run the command pybytes.deepsleep(20000) this command according to the following documentation should put in deep sleep the system for 20 seconds. Certainly the power consumption is going down from ~300mA to 10mA but even this current (i.e. 10 mA) is very high for a low-power system. Especially for our case, it is prohibitive to proceed as our project requires a LoRA Gateway that operats only for 5 minutes during the day and the rest of the day the Gateway should just sleep.
      https://docs.pycom.io/pybytes/api/deepsleep/#app
      Any ideas are welcome!
      Re: PyGate - Temperature and power consumption
      • rcolisteteR Offline
        rcolistete
        See this board, SparkFun Nano Power Timer - TPL5110.
        "Selectable Time intervals: 100ms to 7200s (2 hours)"
        But you can place your own resistor to define a longer time.
        I've tested this board and the current is about 40 nA when the output is off.
        PS : fixed the text, it is 40 nA, not 40 uA.
        robert-hhR A 2 Replies Last reply Reply Quote 0
          robert-hh @rcolistete
          @rcolistete 40µA or 40nA? The data sheet tells of 40nA, and the board has barely more than just that chip and a transistor. So what consumes 40µA?
          rcolisteteR 1 Reply Last reply Reply Quote 1
            rcolistete @robert-hh
            @robert-hh Thanks, it was a typo error.
              rcolistete
              Another option is to modify "robert-hh / ATTiny-Watchdog-for-MicroPython" repository to use the ATTiny (85, etc) to turn on/off PyGate with LoPY4 using a MOSFET.
              ATTiny 85 power usage :
              • active mode, approx. 0.7-3.6 mA @ 3.0V 1-8 MHz;
              • in deepsleep mode : 0.1-0.2 uA @ 3.0V without interrupts, 5 uA with interrupts.
              http://www.technoblogy.com/show?KX0
              https://www.re-innovation.co.uk/docs/sleep-modes-on-attiny85/
              https://arduino.stackexchange.com/questions/13983/attiny85-power-consumption-vs-clock-speed
                anikolaid @rcolistete
                @rcolistete Thank you for elaborating on this! I had assumed that Pycom products don't need any kind of h/w modification in order to support low-power...The fact that I'm still to measuring 10-12mA in deep sleep mode (even trying the available methods, i.e. pybytes.deepsleep, machine.deepsleep) is really strange for a product series claiming to have been designed for low-power IoT applications.
                  rcolistete
                  It is really hard to find any low power LoRawan gateway, as gateways are designed to work 24/7.
                    Did you remove the jumper on the header on the PyEthernet module? You can find this next to the large magnetics IC. This jumper allows for a basic current draw for some PoE modules, or they will switch off completely. I believe the current is indeed close to 10mA, but Im not exactly sure. Removing the small jumper removes the default load from the circuit.
                    Best,
                      anikolaid @Gijs
                      @Gijs Thank you for your recommendation. I don't use the PoE module, only Lopy4 connected to the PyGate. I use (and measure) the current of external power (i.e. Li battery) port of the PyGate.
                        Sorry, read too quickly.
                        For your solution, I believe the external watchdog timer would be preferable. We have no sort of deepsleep built into the Pygate, like the Pysense 2 and Pytrack 2 have, where the power to the development module is cut off, having only the USB controller pic running to keep track of time, as the general use-case of the Pygate is to be on all the time. You could still try to desolder the LEDs and cut some power there. Other than that, I dont think it is possible without hardware / firmware modifications.
                          anikolaid @Gijs
                          @Gijs Thank you for saving me a lot of time! I think it would be a good idea to clarify that in the PyGate datasheet.
                            @rcolistete thank you for indicating this! I've just purchased 2 items of the Nano Power Timer.
                            I've followed all the instructions given here but it does not work. To be more specific:
                            1. I have connected the power (5V) to the Vin pins and the Vout pins are powering the Extension Board v3.0 (with a LoPy4) via the USB connector of the Ext. Board.
                            2. Also, I connected the output pin P19 to the DONE pin of the Nano Power.
                            3. Delay via Dip Switch: 1 min
                            The issue: Once I plug-in the external input (5V) to the Nano Power, the Extension Board never turns on. If I put the push button of the Nano Power for 1 second then the Extension Board turns on for around 15 seconds and then turns off again.
                            Any ideas?
                              rcolistete
                              I've tested the SparkFun Nano Power Timer board some months ago, it was working ok, but it wasn't powering Expansion Board.
                              What about :
                              • using LiPo/LiIon battery to avoid any USB cable to power Expansion Board ?
                              • powering LoPy4 directly, from Vin (3.0-5.5V) ?
                              Why 15 s ? Is there any code in LoPy4 enabling the DONE pin of the Nano Power Timer ?
