    LoPy4 change uplink channels by itself?
    31 Posts 4 Posters 505 Views 5 Watching
    • Gusti Made Arya WijayaG Offline
      hello @robert-hh I have uploaded firmware from https://github.com/robert-hh/Shared-Stuff.git and then uploaded script that I posted previously. but my lopy4 still can't join AS923-2 (921.4MHz & 921.6MHz ).
      robert-hhR Gusti Made Arya WijayaG 2 Replies Last reply Reply Quote 0
        robert-hh @Gusti Made Arya Wijaya
        @Gusti-Made-Arya-Wijaya Don't you have to call prepare_channels before lora.join()? And do you have a gateway in reach?
        Gusti Made Arya WijayaG 1 Reply Last reply Reply Quote 0
          Gusti Made Arya Wijaya @robert-hh
          @robert-hh hello, sorry for super late reply, I have tried it, but still can't join using gateway with AS923-2 freq plan, If I replace the gateway with AS923-1 freq plan, my Lopy4 can join. So the freq play from lopy4 is not change
            Gusti Made Arya Wijaya @Gusti Made Arya Wijaya
            @Gusti-Made-Arya-Wijaya @robert-hh Hello Robert, Should I modify region.c file in ...../pycom-micropython-sigfox/lib/lora/mac/region then re-compile the firmware? or can use this firmware https://github.com/robert-hh/Shared-Stuff.git ?
              @Gusti-Made-Arya-Wijaya Didn't you try already the firmware from Shared Stuff and it did not work? In that case, you have to change the source files and build your own firmware.
                @Gusti-Made-Arya-Wijaya There was this bug that ora.remove_channel(i) did not work for the CN470 region. I made a PR in Aug 2020 to fix that, but I cannot tell whether that was implemented. I do not see it in the Release/v1.20 branch, which seems to be the most recent one, with the most recent change on Dec 6, 20121. The repository management of Pycom is by black box. With many branches of unclear usage.
                  @robert-hh yes, I have tried it and tested my code like on previous page. Is there any guidance to build custom firmware?
                    @Gusti-Made-Arya-Wijaya There is in the README.MD of the pycom-micropython-sigfox directory, and in the ESP32 port directory. It's tricky to set up the build environment. It has to be a Linux OS.
                      @robert-hh yes, the bug in lora.remove_channel(i) is not fixed yet, I think lora.remove_channel(i) is not work in all regions. Need help to fix it, because in Indonesia using AS923-2
                        @Gusti-Made-Arya-Wijaya I added a 1.20.2.r6 version for LoPy4 with the cn470 channel remove fixed to Shared stuff. Maybe that one works.
                          @robert-hh Okay thanks, I will try this firmware, and test lora.remove_channel(i), then add channel AS923-2 freqs (921.4MHz & 921.6MHz ).
                          • 1
                          • 2
                          • 2 / 2
